Router Script
Aug 17th, 2010
Is possible than a router  generate each eight hours a ping to a IP address predefined?
Overall Rating: 3 (1 ratings)
Jason Fraioli Tue, 08/17/2010 - 07:13
Possibly an EEM applet, maybe something like the following.  Check out the link below, it has some great info about this sort of thing.
event manager applet email_server_unreachable
event track 10 state down
action 1.0 syslog msg "Houston we have a problem. Ping failed, server unreachable!"
action 1.1 cli command "enable"
action 1.2 cli command "del /force flash:server_unreachable"
action 1.3 cli command "show clock | append server_unreachable"
action 1.4 cli command "show ip arp | append server_unreachable"
action 1.5 cli command "show ip route | append server_unreachable"
action 1.6 cli command "show interface FastEthernet0/1/1 | append server_unreachable"
action 1.7 cli command "more flash:server_unreachable"
action 1.8 mail server "$_email_server" to "$_email_to" from "$_email_from" subject "Server Unreachable: ICMP-Echos Failed" body "$_cli_result"
action 1.9 syslog msg "Server unreachable alert has been sent to email server!"
I copied the info from:
Jason Fraioli Tue, 08/17/2010 - 12:03
You could use TCL and if you have 12.3 IOS (might be 12.4) you can run a kron to kick off the timer.  You are going to have to work out the details on notification of failures, etc, because I am just learning EEM and TCL myself.
TCL: save this code as "ping_ip1.tcl" (or whatever you'd like, just make changes below to reflect the new filename).  Once saved, load into flash, or onto a TFTP server.  If you store anywhere other than flash, be sure to change the IOS kron line below (tclsh tftp/ftp/disk0/etc).
foreach ip {
ping $ip
kron policy-list ping_ip1
tclsh flash:/ping_ip1.tcl
kron occurrence ping_ip1 in 8:0 recurring
Edit: See this script for an example of how to get email notifications...
