08-17-2010 06:45 AM
I had a couple of jobs that are in "Stop Initiated" state, but they never actually stop. If I try to delete the job, I'll get: RMEJOB0004: Could not delete following jobs: 1634 This is because these jobs may be running.
Can anyone shed some light on how to purge these jobs out of RME?
Solved! Go to Solution.
08-17-2010 11:20 PM
Try starting the job's daemon with the pdexec command to see if that kick starts it into cycling out of the system. If not, then manually unregister it with:
pdreg -u 1608
Then see if you can delete it.
08-17-2010 01:23 PM
Check the output of pdshow to see if there is a daemon running for the job ID. If so, run pdterm on that job ID to kill it. Then see if the job stops in the GUI.
08-17-2010 01:46 PM
Process= 1608
State = Administrator has shut down this server
Pid = 0
RC = 0
Signo = 0
Start = N/A
Stop = Not applicable
Core = Not applicable
Info = Not applicable
The job remains in "Stop Initiated" state in the GUI. If I try to delete it, I'll get:
RMEJOB0004: Could not delete following jobs: 1608
The hung netconfig job gives this error:
CFG0012: Failed while deleting job(s)
Possible Cause: Could not delete job in JRM:1634
08-17-2010 11:20 PM
pdreg -u 1608
