VIP out of service
Answered Question
Aug 17th, 2010
Hi All ,
Please find  the below  steps and help us   to bring up the  VIP.
1)We could see the r server status as active but   the concerned probes  for the rserver showing as failed  .
2)Also we are getting the status of the  VIP as out of service.
3) We  ensured the  rservers are responding  for the  probe (http ).
5) We  removed  and applied the  inservice  and tested but it  is  not coming up  .
For your reference I am attaching the configuration what we have done.
A) Configuration
1)  probe http DC_MC-ACC-HTTP_PROBE
  interval 5
  faildetect 2
  passdetect interval 2
  receive 2
  expect status 200 400
  open 2
2)   TestACE(config)# rserver host  DCweb01
TestACE(config-rserver-host)# ip address  10.199.7.222
TestACE(config-rserver-host)# inservice
TestACE(config)# rserver host  DCweb02
TestACE(config-rserver-host)# ip address  10.199.7.223
3)   TestACE(config)# serverfarm host   DC_HTTP_SF_NEW_80
TestACE(config-sfarm-host)# probe  DC_MC-ACC-HTTP_PROBE
TestACE(config-sfarm-host)# rserver   DCweb01   80
TestACE(config-sfarm-host-rs)# inservice
TestACE(config-sfarm-host)# rserver   DCweb02   80
4)  policy-map type loadbalance first-match   DC-HTTP-NEW
  class class-default
    serverfarm   DC_HTTP_SF_NEW_80
5)   VIP
TestACE(config)# class-map match-any     DC_MC-VIP -HTTP
TestACE (config-cmap)#  2 match virtual-address     10.199.7.226   tcp  eq  80
6)
            policy-map multi-match LB-VIP
               class   DC_MC-VIP-HTTP
             loadbalance vip inservice
    loadbalance policy    DC-HTTP-NEW
    loadbalance vip icmp-reply
7) service-policy input DC_TI-HTTP
B)
TestACE# sh service-policy  DC_TI-HTTP class-map  DC_MC-VIP-HTTP summary
service-policy: DC_TI-HTTP
Class                            VIP             Prot  Port        VLAN          State    Curr Conns   Hit Count  Conns Drop
DC_MC-VIP-HTTP                 10.199.7.226    tcp   eq 80       ALL           OUT-SRVC          0          80         80
So please suggest us how can I trouble shoot it and  bring it up   .
Thanks  and regards,
Sinjish.K
Correct Answer by EPHRAIM MANI about 6 years 6 months ago
Hey Sinjish, have your post makred Answered to help others. Thanks
So Sinjish.K, what exactly your query or problem is now, litrenta
  thanks for your explaination.
Correct Answer by litrenta about 6 years 6 months ago
this probe is  is sucessful it hasn't failed on this server since jul 19
last response was 302 which falls in teh range so it is good.
what do you see for probe on server that is in the probe_failed state ?
IF you can't share config here you may be better off with a tac case.
Overall Rating: 5 (9 ratings)
litrenta Tue, 08/17/2010 - 11:47
what do you see for output of
show probe  DC_MC-ACC-HTTP_PROBE detail ?
litrenta Tue, 08/17/2010 - 11:48
also what do you see with
sh service-policy  DC_TI-HTTP class-map  DC_MC-VIP-HTTP detail
k_sinjish Tue, 08/17/2010 - 13:49
Hi ,
The  server farm what I have mentioned  earlier DC_HTTP_SF_NEW_80  in the given  configuration is a  typo .
So please  take it as  DC_HTTP_SF_NEW
The output what  I have taken  is from direct  ACE  , if there  are any minor change with the given conf  please treat the below pasted as right one .
Also we observed in the  probe details the  serverfarm is not being displayed . So please suggest us do I need to make  any more conf  apart from the above given conf )
1. TestACE# sh probe DC_MC-ACC-HTTP_PROBE detail
probe       : DC_MC-ACC-HTTP_PROBE
type        : HTTP
state       : ACTIVE
description :
   port      : 80      address     : 0.0.0.0         addr type  : -
   interval  : 5       pass intvl  : 2               pass count : 3
  fail count: 2       recv timeout: 2
   http method      : GET
   http url         : /
   conn termination : GRACEFUL
   expect offset    : 0         , open timeout     : 2
   expect regex     : -
   send data        : -
                       --------------------- probe results --------------------
   probe association   probed-address  probes     failed     passed     health
   serverfarm  : DC_MC-ACC-HTTP
     real      :DCmctiweb01[80]
                       10.199.7.164    1343852    250        1343602    SUCCESS
   Socket state        : CLOSED
   No. Passed states   : 27         No. Failed states : 26
   No. Probes skipped  : 33         Last status code  : 400
   No. Out of Sockets  : 0         No. Internal error: 0
   Last disconnect err :  -
   Last probe time     : Tue Aug 17 21:32:37 2010
   Last fail time      : Thu Jul  8 13:10:01 2010
   Last active time    : Thu Jul  8 13:10:08 2010
     real      :DCmctiweb02[80]
                       10.199.7.165    1343841    210        1343631    SUCCESS
   No. Passed states   : 19         No. Failed states : 18
   No. Probes skipped  : 32         Last status code  : 400
   Last probe time     : Tue Aug 17 21:32:36 2010
   Last fail time      : Thu Jun 24 09:33:07 2010
   Last active time    : Thu Jun 24 09:33:14 2010
   serverfarm  : DC_MC-ACC-HTTPS
TestACE#
2) TestACE# sh service-policy DC_TI-HTTP class-map DC_MC-VIP-HTTP detail
Status     : ACTIVE
Description: -----------------------------------------
Context Global Policy:
    class: DC_MC-VIP-HTTP
     VIP Address:    Protocol:  Port:
      loadbalance:
        L7 loadbalance policy: DC-HTTP-NEW
        VIP Route Metric     : 77
        VIP Route Advertise  : DISABLED
        VIP ICMP Reply       : ENABLED
        VIP state: OUTOFSERVICE
        curr conns       : 0         , hit count        : 80
        dropped conns    : 80
        client pkt count : 80        , client byte count: 4800
        server pkt count : 0         , server byte count: 0
        conn-rate-limit      : 0         , drop-count : 0
        bandwidth-rate-limit : 0         , drop-count : 0
        L7 Loadbalance policy : DC-HTTP-NEW
          class/match : class-default
            LB action: :
               primary serverfarm: DC_HTTP_SF_NEW
                    state: DOWN
                  backup serverfarm : -
            hit count        : 0
            dropped conns    : 0
Here  we can ping to the rservers  as well   can do the telnet to the same with port – 80 ( But the serverfarm state showing as down  -  also  we ensured the  inservice command  applied  early ).
k_sinjish Tue, 08/17/2010 - 23:55
Hi ,
I am very  sorry  to say no because of  some security reason and company policy I could  not share the tech support . Probably you can help me by giving any trouble shooting method or by providing  any of your findings. Also  please let us know if you faced any issues that are similar to what I have given .
Thanks & Regards,
Sinjish.K
EPHRAIM MANI Wed, 08/18/2010 - 01:33
Can you paste the output of  sh serverfarm DC_HTTP_SF_NEW_80 and make sure they are in "in service" state.
k_sinjish Wed, 08/18/2010 - 03:44
Please find  the output  as probe failed in serverfarm  . We have already configured probe in the  serverfarm .Also the serverfarm showing  as INACTIVE. We removed and applied again the inservice but there is no effect . The serverfarm name is DC_HTTP_SF_NEW . There are some changes in  names then what i given  previously .
Test _ACE1/DC# sh serverfarm DC_HTTP_SF_NEW detail
serverfarm     : DC_HTTP_SF_NEW, type: HOST
total rservers : 2
active rservers: 0
description    : -
state          : INACTIVE
predictor      : ROUNDROBIN
failaction     : -
back-inservice    : 0
partial-threshold : 0
num times failover       : 0
num times back inservice : 0
total conn-dropcount : 0
Probe(s) :
    HTTP_PROBE,  type = HTTP
                                                ----------connections-----------
       real                  weight state        current    total      failures
   rserver: xxxxDCmctiweb01
       10.199.7.222:80       8      PROBE-FAILED 0          0          0
         description          : -
         max-conns            : -         , out-of-rotation count : -
         min-conns            : -
         conn-rate-limit      : -         , out-of-rotation count : -
         bandwidth-rate-limit : -         , out-of-rotation count : -
         retcode out-of-rotation count : -
         load value           : 0
   rserver: xxxxDCmctiweb02
       10.199.7.223:80       8      PROBE-FAILED 0          0          0
         description          : -
         min-conns            : -
         load value           : 0
litrenta Wed, 08/18/2010 - 04:54
without more data it is hard to say. IF the probe is failing then we need to see what gets returned on the probe. IF you are doing an http probe that is failing but van telent to the server on port 80 then the possibilities are:
server is returning something outside the range of response codes (404 for example).
or
Server responds but does not send a fin. normally
ace sends get or head and sends fin then server sends response and sends fin.
if server does not send fin probe will fail. a packet capture on server will reveal this.
If this is the case then you should configure another probe for this farm with the same parameters but with the addition of "connection term forced"
k_sinjish Wed, 08/18/2010 - 05:49
Hi ,
Thanks for your support .
I have  removed the existing probe and created a simple probe with the   below configuration .
probe tcp HTTP_TEST
  interval 4
  passdetect interval 10
  passdetect count 4
Now it is working fine .  Also the  VIP turned as inservice .
So also please let me know what I  need to do  on server  side to enable the below probe .
probe http HTTP_PROBE
  interval 5
  faildetect 2
  receive 2
  expect status 200 302
  open 2
I   could not find the command  - connection term forced in the serverfarm  mode . Also please let me know what is the use of   - expext status  200 302 .
Sinjish.K
litrenta Wed, 08/18/2010 - 06:00
connection term forced goes under probe config not serverfarm config
expect status 200 302 means that server  http response needs to be in the range of 200-302
when you configure the probe and then apply to serverfarm you need to do
show probe HTTP_PROBE detail
to get a clue as to how server is responding.
k_sinjish Wed, 08/18/2010 - 07:27
Hi  ,
Please find  the below output and please  suggest us how can i know the server responding  in which value   for setting the " expect value " in probe .
Is it the last status code  in the below output ?
Test/DC# sh probe HTTP_PROBE detail
probe       : HTTP_PROBE
type        : HTTP
state       : ACTIVE
description :
   http method      : GET
   http url         : /
   expect regex     : -
   send data        : -
   serverfarm  : DC_PRODUCTION
     real      : XXXDCWEB01[80]
                       10.199.7.196    1357262    1518       1355744    SUCCESS
   No. Passed states   : 112         No. Failed states : 111
   No. Probes skipped  : 894         Last status code  : 302
   Last probe time     : Wed Aug 18 15:58:53 2010
   Last fail time      : Mon Jul 19 01:24:54 2010
   Last active time    : Mon Jul 19 01:25:01 2010
In this case the expect value in probe is  200 and 302.
Regards ,
Sinjish.K
Correct Answer
litrenta Wed, 08/18/2010 - 07:38
Correct Answer
EPHRAIM MANI Wed, 08/18/2010 - 21:23
k_sinjish Wed, 08/18/2010 - 22:56
Hi  EphraimMani,
My problem solved  after i applied the proble without the expect  value .
Thanks  everyone and  Litrenta for your help and support .
Sinjish.K
Correct Answer
EPHRAIM MANI Thu, 08/19/2010 - 00:02
