verifying reverse dns is working
Aug 17th, 2010
i have a connection that is being made pretty quickly, but when i change the ip and try the connection i am not able to quickly go through the connection process and because its not happening fast enough the connection is being dropped,
how can i verify that reverse dns is working and that settings are right
Kureli Sankar Sat, 08/21/2010 - 15:08
I am not sure is I understand the question correctly.
You are asking how you can verify that the IP address that you look like on the internet has a PTR record created? and how to test it?
From a PC on the internet you can do
ping -a x.x.x.x
replace x.x.x.x with the ip address and if it returns a name then the reverse dns is working.
