Test MTU Size Over IPSEC Tunnel
jtmullis82
How can I test the MTU size going over a IPSEC tunnel from a ASA 5520 to a ASA 5510? I am having concerns that the issues with my equipment are due to insufficient MTU size.
manish arora
Level 6
Level 6
You can use extended ping to see the size of packet that you can send over the tunnel with DF bit
set do not fragment. for ex :-
if you have two windows machines , one on each side of the vpn with ip add 10.2.2.10 and 10.3.3.10.
ping from 10.2.2.10 using :-
ping 10.3.3.10
reply success
ping 10.3.3.10 -l 1500 -f  { where -l 1500 sets the MTU to 1500 and -f says do not fragment }
packet needs to be fragmentated but df set
ping 10.3.3.10 -l 1300 -f
packets needs fragmentation but df set
ping 10.3.3.10 -l 1270 -f
reply success
reply success
thanks
manish
manish arora
Level 6
Level 6
ping 10.3.3.10
reply success
reply success
reply success
thanks
manish
