7600 - Supervisor-Other - Unknown
Aug 17th, 2010
am upgrade ios to router7600 but am upload new ios to sup-bootdisk only and then am reload the router i saw this log
Mod Ports Card Type                              Model              Serial No.
  1    0  2 port adapter Enhanced FlexWAN        WS-X6582-2PA       JAE120107Y3
  2    0  4-subslot SPA Interface Processor-400  7600-SIP-400       JAE1052J698
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3BXL     JAF1201AHCJ
  6    0  Supervisor-Other                       Unknown            Unknown
module 6 it can't boot.
am try to boot ios to last version but module 6 can't boot also.
Can anyone help me ?
Pavol Golis Fri, 08/20/2010 - 05:02
  • Cisco Employee,
Have you copied image to slavesup-bootdisk: as well ? Your standby is most likely stuck in ROMMON as bootvar is pointing to the image he cannot found on his flashdisk. Just connect to the console port of it, enter "boot", your system will end up in RPR redundancy mode, then copy image from active to standby and reload stanby (hw-module module..).
Pavol Golis Tue, 08/24/2010 - 01:05
  • Cisco Employee,
He can, but for that you need "boot system flash", otherwise if it wont find image to which startup-config is pointing, he will end up in the ROMMON.
