Waas DUP! ping
Aug 17th, 2010
I just installed waas in version 4.2.1 and got a weird ping result. On the core wae  I enabled the management interface as gig1/0 ( and the gigi 2/0 just for wccp with the router ( and the default gateway on the same subnet as the management interface. When I do a ping to the management interface of the waas from a remote location I get this duplicate pings, when I perform a trace route this does not happen. Is this an expected behavior?
PING ( 56(84) bytes of data.
64 bytes from icmp_seq=1 ttl=58 time=18.8 ms
64 bytes from icmp_seq=1 ttl=58 time=20.9 ms (DUP!)
64 bytes from icmp_seq=2 ttl=58 time=17.9 ms
64 bytes from icmp_seq=2 ttl=58 time=19.6 ms (DUP!)
--- ping statistics ---
2 packets transmitted, 2 received, +2 duplicates, 0% packet loss, time 999ms
rtt min/avg/max/mdev = 17.914/19.329/20.973/1.127 ms
mhollowa Tue, 08/17/2010 - 16:05
You do not mention what the remote-wae is - does it have an in-line card?  Do you see the same behavior from a PC behind  the remote-wae?
mario-leitao Tue, 08/24/2010 - 15:44
The remote wae is using Wccp (I do not have an inline card there but I am using just one interface for Management and wccp). If I ping from the remote PC I do not see this behavior.
