error on ATM interface
Aug 17th, 2010
  • Bronze, 100 points or more
Dears ,
I'm seeing too many input errors and aborts  on my ATM interface .
  488308 input errors, 0 CRC, 0 frame, 2098 overrun, 0 ignored, 488417 abort
What could be the problem ? I heard that this can be because of NPE limitation ? Is there is any work around ?
I'm using  PA-A1-OC3SM with 7206vxR (NPE 300)
haris
Giuseppe Larosa Tue, 08/17/2010 - 13:13
  • Hall of Fame,
    Founding Member
Hello Haris,
generally speaking only overrun errors are sign of a performance problems but most of your errors are abort
so I would look for clocking problems rather then performance issues
However, at the following link describing A1 port adapters
and more specifically
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_tech_note09186a00800d77bb.shtml
abort—Counts the number of times that a  cell was dropped due to a receive cell FIFO overrun. More specifically,  aborts are packet drops caused by cell throttling, at the microcode  level, to alleviate framing overruns. Thus, aborts stem from overruns,  and you might see both counters increment on the ATM interface. Aborts  point to congestion on the PCI bus.
before NPE-300 issues the document clearly states this PA has low performances
  • Try replacing the PA-A1 with a PA-A3 (revision 2).
    The PA-A1 has a very shallow receive cell FIFO and is not the best choice for heavy receive traffic or long bursts.
    Hope to help
    Giuseppe
    Haris P Tue, 08/17/2010 - 13:33
    Dear Giuseppe,
    I dont have a PA-A3 ready and it might take some time
    regards,
    Haris P
    Giuseppe Larosa Wed, 08/18/2010 - 03:55
    • Hall of Fame,
      Founding Member
    Hello Haris,
    I'm afraid you could only add a second interface to reduce load on this one
    being an hardware problem there is no configuration workaround
    Hope to help
    Giuseppe
