Cisco Agent Toolkit - Sup Assist Button
Answered Question
Aug 17th, 2010
Guys,
I tried to use the Sup Assist Button in Cisco Agent Toolkit. But, when i clicked in, every agents gets my "Call", because the Sup Assist button have the functionality of answer the agent, if he click the Sup Assist Button. How can i do to call only the supervisors?
Thanks.
Correct Answer by david.macias about 6 years 5 months ago
I mispoke, it's in the Agent Team List.  Have you taken a look at the CTIOS Manager's Guide?  It's all there on how to do this.
david
Overall Rating: 5 (1 ratings)
david.macias Tue, 08/17/2010 - 17:16
I am not sure you're using this correctly or you have not read the documentation.  Check out the CTIOS System Manager document and it will give you an example of how to use the Assist and Emergency buttons.  In short, the Assist button will place the customer on hold and make an outbound call to a dialed number specified in the agent desk setting for that agent.  At that point, the call is treated as any new call with its own ICM script, skill group, etc.
david
Eric Alisson Wed, 08/18/2010 - 05:46
A dialed number specified in the agent desk setting?? I'm looking for this but i didnt found..
Correct Answer
david.macias Wed, 08/18/2010 - 06:35
david
valiegenus Sun, 12/12/2010 - 02:12
1- Define Dialed number with CUCM routing client,and call type : for example  DN_SuperAssist ,CT_SuperAssist
2- go to Agent team list ,create a team  ,assign  supervisor/s ,and agent/s in member tab .and select  DN_SuperAssist  in 'Supervisor script dialed number' feild
3- create Skill group including supervisor/s you want them to assist the members of team.
4- create script and schedule it with dialed number and calltype already defined above i,e  DN_SuperAssist ,CT_SuperAssist
regards
