UC560 PRI
techiegzz
I am currently planning a UC560 deployment with PRI. The provider is speakeasy and the speakeasy customer premise equipment is an Adtran Total Access 916. I was wondering what I need to do to get the PRI to work with UC560, any configurations and how?
Thanx,
You will need a T1 card for your UC560 if it doesnt have one already.
On the line side you will need to know the following:
Framing - SF or ESF (ESF is most common)
Line Code - AMI or B8ZS (B8ZS is most common)
ISDN switch type
time-slot assignments
Using CCA makes it a really easy process.
https://supportforums.cisco.com/docs/DOC-9772
https://supportforums.cisco.com/docs/DOC-9646/
Cole
techiegzz
I am currently planning a UC560 deployment with PRI. The provider is speakeasy and the speakeasy customer premise equipment is an Adtran Total Access 916. I was wondering what I need to do to get the PRI to work with UC560, any details I need to request from the client, any special configurations and how?
Thanx,
ISDN switch type
Cole
Thanx, man. So I need to be on the safe side, I should communicate with the client to request these details from their T1/PRI provider so I know the definite options to apply, right?
You might want to get in touch with the carrier directly, but yes that's correct.
