GUI Problem
Aug 17th, 2010
hi,
I have 4 ace appliances (2 active and 2 hot standby) on different parts of a network. I manage all from a single management segment usually
by SSH but for simple tasks I like the GUI .
my problem is that about once a month I cant seem to manage any of them using the GUI, I use HTTPS to browse to the ACE appliance and get the
Login screen , I put in my username and password and everything seems to be fine but instead of getting into the ACE I get a blank page and a message in the bottom left that says "done" so basically I dont have anything ellse to expect for...
I tried using a different browser ,different rsa sig , different Java , different computer nothing works.
The only way I could get it to work again was by rebooting but then again after a month or so the problem persists .
I could really use your help because I relly both on the CLI and the GUI to manage the appliance and rebooting every month all 4 of them on
a production network is out of the question.
thank you very much
Overall Rating: 5 (6 ratings)
EPHRAIM MANI Tue, 08/17/2010 - 23:42
  • Bronze, 100 points or more
Hi Nir,
Please provide the software versions.
nir.fisher Wed, 08/18/2010 - 23:25
hi,
the version is attached in text file
by the way I have another question , when I clear stats in the CLI it doesnt effect the stats that appear in the monitor tab displayed in the GUI
I couldnt find a way to clear stats in the GUI , only in the CLI .
much thanks for your response
EPHRAIM MANI Thu, 08/19/2010 - 20:35
Thanks Litrenta, for the information
nir.fisher Sun, 08/22/2010 - 08:21
Thanks for the reply
I have a newer version than the one claimed to have fixed this bug
I use Version A3(2.1)
Do I still need to upgrade? (or maby downgrade?)
EPHRAIM MANI Sun, 08/22/2010 - 20:30
Hi Nir, what is the version you are usint righ now ?.. you need to use A2(2.2) and above
litrenta Mon, 08/23/2010 - 04:40
  • Cisco Employee,
Nir
first fixed in A3(2.2) upgeade will resolve it.
nir.fisher Mon, 08/23/2010 - 22:20
I guess I will have to buy the new IOS and try...
thank you for all the efforts
