Disable Telnet on a Catalyst 3750 stack?
Answered Question
Aug 17th, 2010
Hi all,
I have just configured a new Catalyst 3750 switch stack.  I am trying to disable Telnet access to the CLI while leaving SSH open.  The "transport input ssh" command is not available for vty line 0 through 3, and even if I disable Telnet in the Web UI I can still Telnet to the switch.  Is what I am trying to do possible with this model?
- Steve
Correct Answer by Leo Laohoo about 6 years 6 months ago
Try the following:
line vty 0 15
transport input ssh
Overall Rating: 5 (1 ratings)
vragotha Tue, 08/17/2010 - 21:59
What IOS are you running? From the looks of it, you may not have a k9 image running.
Please post a 'show ver' and 'show run' if you do have a k9 image
rstevek Wed, 08/18/2010 - 09:58
Hi Vijay,
Thanks for the response.  I am running a k9 image.  I CAN enable SSH, the problem is that I can't DISABLE Telnet.
- Steve
John Blakley Wed, 08/18/2010 - 11:47
As an alternative, you could create an acl and apply it to your line that only allows port 22.
HTH,
John
vragotha Wed, 08/18/2010 - 21:44
From what you are saying, telnet is still open from lines 4 through 15. You'll want to add the transport input ssh command to all 15 lines to disable telnet
Correct Answer
Leo Laohoo Wed, 08/18/2010 - 15:31
Try the following:
line vty 0 15
transport input ssh
rstevek Thu, 08/19/2010 - 08:52
Hi leolaohoo,
Thanks - that worked.  I'm really confused, though, because originally, "transport input ssh" was not a recognized command on lines 0 through 3.  Now, however, after running the command for vty 0 through 15, I can run the same comamnd on 0 3.  I swear that I am not crazy!  I think I hit some sort of bug.
- Steve
Leo Laohoo Thu, 08/19/2010 - 15:48
Hi Steve,
Thanks for the ratings.
I've never seen this before, however, some Cisco routers (800, 810, 830, 850, 870) will support only up "4".  So I'm suspecting you are getting confused with this.  It's just a forced of habit for me to configure "0 15" all because of a similar mistake I made years ago.
