Can i configure Ethernet over IP (EoIP) on cisco router ?
Aug 17th, 2010
Hello all,
I want to know if i can configure the Ethernet over IP on cisco router. This configuration is possible on Mikrotik equipment.
If yes, what is the commande line please?
Thanks in advance.
Overall Rating: 5 (1 ratings)
Lei Tian Tue, 08/17/2010 - 19:33
  • Cisco Employee,
I guess you want extend a L2 network across L3 IP. If that is case, then yes, it is supported on Cisco router.You can configure a pseudowire between the routers to achieve that. Here is a configuration example.
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/l2tpv325.html#wp1051352
HTH,
Lei Tian
josedunet Wed, 08/18/2010 - 09:19
Please letian, Could i configure the L2VPN without MPLS. Because Quite my searches  speak only about L2VPN with MPLS.
Thanks in advance.
Lei Tian Wed, 08/18/2010 - 09:27
  • Cisco Employee,
Yes, MPLS is not required for pw with L2TPV3 encapsulation. Please read the configuration example that I posted from previous reply.
HTH,
Lei Tian
