Router throughput consideration
Answered Question
Aug 17th, 2010
We have 4 branch offices connected thru 100mbps link with Cisco 2600 routers which has the throughput of 15mbps.
Now I am planning to replace these routers with Cisco 2901G2 ISR routers which has the throughput of 167mbps.
So if I replace the routers at one location first is it going to put more load on other routers as the new routers can handle more traffic than other 2600 routers? Should I replace all routers at once?
Correct Answer by kyukim about 6 years 11 months ago
HI,
Yes, it will shape your traffic as 20 mbps average.
You can only apply Shaping on outgoing direction.
You can check how policy working by "sh policy-map int" and sh int.
KK.
It is possible that new router in one location will send out more traffic to other branches if users sends out more traffic from this new location to other location.
But, you can prevent this with shaping policy applied to your new router's outgoing interface if you experience this issue.
int G0/0
service-policy pm-shape out
policy-map pm-shape
class class-default
  shape average 15000000
So, I would replace one location first and monitor.
If you find congestion on other location as new router sends out more than 15 mbps, then you can apply above shape policy to restrict new router's capability until all locations are upgraded.
KK
Overall Rating: 5 (2 ratings)
Correct Answer
kyukim Tue, 08/17/2010 - 20:17
  • Cisco Employee,
int G0/0
policy-map pm-shape
class class-default
KK
avilt Tue, 08/17/2010 - 22:29
Thank You for your inputs. Could you provide me some examples/links where this shaping policy is used. What is the ideal bandwidth limit I should set on Cisco 2621 router?
avilt Sun, 08/22/2010 - 19:47
I have started experiencing the problem on other old routers. I want to make sure that the bandwidth utilization on this new router for the interface G0/0 will not exceeded 20Mbps (both In/Out). Is the following command enforce this?
int G0/0
service-policy output My-shape
policy-map My-shape
class class-default
shape average 20000000
Appreciate a quick reply.
Correct Answer
kyukim Sun, 08/22/2010 - 22:21
  • Cisco Employee,
HI,
KK.
