Create User Account
Answered Question
Aug 17th, 2010
We have VPN 3005 Concentrator.  I want to create a local user for the purpose of authentication.  This user does not have any permissions.  For example, after the Cisco VPN client has been installed,  I want the users to use  this account to login to make sure the authentication works.   How do you create this local user account?  What group name do I need to use?
Thanks.
Correct Answer by Jennifer Halim about 6 years 5 months ago
To create local user account, go to: Configuration | User Management | Users, and click on "Add".
You just have to fill in the username, password, verify and groupname.
The groupname would be the VPN Client group that you would like the user to access to.
Hope that helps.
Overall Rating: 5 (1 ratings)
Correct Answer
Jennifer Halim Tue, 08/17/2010 - 22:24
Hope that helps.
