Warning message
CCM 7 offnet Call duration limitation
Aug 17th, 2010
Dears,
I have CCM6 installed and using MGCP to control my vgw. I have route pattern, for example 9.050xxxxxxx which points to FXO port (PSTN). Is there an option to limit call duration, sent trought this FXO, say, to 3 minutes, and, when this port becomes unused, inform first user, who tried to use this line that this line is free now.
Thank you!
Overall Rating: 5 (2 ratings)
Matthew Kaufman Mon, 08/23/2010 - 12:27
  • Cisco Employee,
There is no feature within CUCM that I am aware of which can do this.
Sorry.
--Matt
paolo bevilacqua Mon, 08/23/2010 - 12:43
  • Hall of Fame,
    Founding Member
Thank you Javalenc for pointing to my work.
My script (once released), is also able to call back, inform that the line became free and give dialtone.
Jaime Valencia Mon, 08/23/2010 - 12:48
  • Cisco Employee,
  • Hall of Fame,
    2011
You're welcome Paolo, I thought your script would only do the time limit but it seems you covered everything a user would want it to do. =)
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
paolo bevilacqua Mon, 08/23/2010 - 12:54
  • Hall of Fame,
    Founding Member
As an ancient say says:
"Let the power of TCL walk by your side,
To the nearest CO, there is free wire inside".
