7945 Light strip on the handset do not light up
Aug 17th, 2010
Hi,  The light strip on the handset do not light up even when messages are left in the mailboxes. Version used is CME 7.1 with CUE 7.1.  I read that you need to set MWI on to the DN.  With CUE 7.0 i have no problem with the below config. The light strip just worked. Can someone pls advise.
ephone-dn 90 dual-line
number 3890
label Testing - 3890
description (03) 8968-3890
name Testing
call-forward max-length 12
call-forward busy 3899
call-forward noan 3899 timeout 17
hold-alert 30 originator
brendand05 Tue, 08/17/2010 - 23:26
Sounds like a dodgy firmware.
Upgrade/downgrade the 7945 firmware and try again.
lpoon Tue, 08/17/2010 - 23:31
Hi, I am using the below firmware, anybody encounter the same problem??
tftp-server flash:apps45.8-5-4TH1-6.sbn
tftp-server flash:cnu45.8-5-4TH1-6.sbn
tftp-server flash:cvm45sccp.8-5-4TH1-6.sbn
tftp-server flash:jar45sccp.8-5-4TH1-6.sbn
tftp-server flash:SCCP45.8-5-4S.loads
tftp-server flash:dsp45.8-5-4TH1-6.sbn
lpoon Wed, 08/18/2010 - 00:41
Downgraded 7945 firmware to SCCP45.8-5-2S. No joy....Problem still there.  Anybody any suggestions.
Paolo Bevilacqua Wed, 08/18/2010 - 02:40
  • Hall of Fame,
    Founding Member
Likely misconfiguration in CUE/CME MWI settings.
I recommend to use unsolicited notify that is the simpler option and works very well.
Note, there is a MWI refresh command from CUE for testing.
