08-18-2010 01:08 AM
Hi ,
Please find the below probe configuration of probe and the probe failed out put of t he server farm
But the same probe is operational for some other serverfarm .
Also we can telnet to the server with port number 80 . So please tell us if we need any other criteria to be met for configuring the probe .
Here the serverfarm status also showing as INACTIVE .So we are suspecting this is because of the probe failure .
Test/DC# sh serverfarm DC_HTTP_SF_NEW detail
serverfarm : DC_HTTP_SF_NEW, type: HOST
total rservers : 2
active rservers: 0
description : -
state : INACTIVE
predictor : ROUNDROBIN
failaction : -
back-inservice : 0
partial-threshold : 0
num times failover : 0
num times back inservice : 0
total conn-dropcount : 0
Probe(s) :
HTTP_PROBE, type = HTTP
----------connections-----------
real weight state current total failures
rserver: DCmctiweb01
10.199.7.222:80 8 PROBE-FAILED 0 0 0
description : -
max-conns : - , out-of-rotation count : -
min-conns : -
conn-rate-limit : - , out-of-rotation count : -
bandwidth-rate-limit : - , out-of-rotation count : -
retcode out-of-rotation count : -
load value : 0
rserver: DCmctiweb02
10.199.7.223:80 8 PROBE-FAILED 0 0 0
description : -
min-conns : -
load value : 0
2)) Probe Configuration
probe http DC_MC-ACC-HTTP_PROBE
interval 5
faildetect 2
passdetect interval 2
receive 2
expect status 200 400
open 2
Regards ,
Sinjish.K
08-18-2010 01:31 AM
Do you configure 'HTTP_PROBE' and apply this probe to DC_HTTP_SF_NEW?
When I configure 'DC_MC-ACC-HTTP_PROBE' probe and apply it to serverfarm,
show serverfarm output is as below.
ACE20/Admin# sh serverfarm detail
serverfarm : sf, type: HOST
total rservers : 2
active rservers: 0
description : -
state : INACTIVE
failaction : -
back-inservice : 0
num times back inservice : 10
Probe(s) :
DC_MC-ACC-HTTP_PROBE, type = HTTP <<==
Your output was 'HTTP_PROBE'. So, I guess you configure 'HTTP_PROBE' and apply to DC_HTTP_SF_NEW, not 'DC_MC-ACC-HTTP_PROBE'.
I couldn't see DCweb01(10.199.7.222) and Cweb02(10.199.7.223) in show probe detail output in previous discussion. Normally, we can see them.
https://supportforums.cisco.com/thread/2037302
If you configure 'HTTP_PROBE', please check 'show probe HTTP_PROBE detail'?
I checked above behavior with A2(3.1). Even If you configure probe and apply it to serverfarm correctly, please let me know your version?
Yuji
08-18-2010 03:57 AM
HI ,
I have configured the probe with the correct serverfarm only .The hostname change might be a typo.
Test _ACE1/DC# sh serverfarm DC_HTTP_SF_NEW detail
total rservers : 2
active rservers: 0
description : -
state : INACTIVE
failaction : -
back-inservice : 0
Probe(s) :
rserver: xxxxDCmctiweb01
description : -
min-conns : -
load value : 0
rserver: xxxxDCmctiweb02
description : -
min-conns : -
load value : 0
Test _ACE1/DC # sh serverfarm DC_HTTP_SF_NEW
total rservers : 2
rserver: xxxDCctiweb01
rserver: xxxDCctiweb02
Also please find the device details .
Software
loader: Version 12.2[120]
system: Version A2(3.0) [build 3.0(0)A2(3.0)]
system image file: [LCP] disk0:c6ace-t1k9-mz.A2_3_0.bin
installed license: ACE-VIRT-020 ACE-VIRT-UP1 ACE-VIRT-UP2
Please suggest me what will be the reasons for getting the probe failed.Also from the ACE I can telnet to the server with port number 80 . (The probe is also HTTP)
Regards ,
Sinjish.K
08-18-2010 08:57 AM
I want to make clear whether probe status goes FAILED or not.
So, please get 'show probe detail | b 10.199.7.222' and 'show probe detail | b 10.199.7.223'.
If these probe are SUCCESS, please get 'show probe detail | i FAILED' and 'sh run serverfarm | b DC_HTTP_SF_NEW'.
08-19-2010 05:34 AM
Hi ,
After trying with another probe without expect value the probe has turned up .And I got update from net pro as we need t o apply - connection term forced in the probe configuration if we are not sure , what ( response) value being returned from server .
Thanks everyone .
Regards ,
Sinjish.K
