%C4K_REDUNDANCY-4-KEEPALIVE_WARNING:
deepaks_1974
Sir,
we have used Cisco 4507 in our network as distribution switch and since last IOS upgradation we have observe below mentioned log.
SUP failover observe.
Need for help if problem occurs repeatedly.
Aug 18 10:57:08.173: %SSH-5-ENABLED: STANDBY:SSH 1.99 has been enabled
Aug 18 10:57:08.973: %SYS-6-LOGGINGHOST_STARTSTOP: STANDBY:Logging to host 10.4.
52.79 Port 514 started - CLI initiated
Aug 18 10:57:08.981: %SYS-6-LOGGINGHOST_STARTSTOP: STANDBY:Logging to host 10.4.
52.179 Port 514 started - CLI initiated
Aug 18 11:55:40.573: %C4K_REDUNDANCY-4-KEEPALIVE_WARNING: STANDBY:Keepalive mess
ages from peer Supervisor are missing for 27 seconds
Aug 18 11:56:07.572: %C4K_REDUNDANCY-4-KEEPALIVE_WARNING: STANDBY:Keepalive mess
ages from peer Supervisor are missing for 54 seconds
Aug 18 11:56:34.571: %C4K_REDUNDANCY-4-KEEPALIVE_WARNING: STANDBY:Keepalive mess
ages from peer Supervisor are missing for 81 seconds
Aug 18 11:57:01.570: %C4K_REDUNDANCY-4-KEEPALIVE_WARNING: STANDBY:Keepalive mess
ages from peer Supervisor are missing for 108 seconds
Aug 18 11:57:26.573: %C4K_REDUNDANCY-6-INIT: Initializing as ACTIVE supervisor
Aug 18 11:57:26.581: %C4K_REDUNDANCY-3-COMMUNICATION: Communication with the pee
r Supervisor has been lost
Aug 18 11:57:26.621: %C4K_REDUNDANCY-3-SIMPLEX_MODE: The peer Supervisor has bee
n lost
Aug 18 11:57:26.665: %HSRP-5-STATECHANGE: Vlan131 Grp 131 state Init -> Active
Aug 18 11:57:26.877: %C4K_EBM-4-HOSTFLAPPING: Host 00:10:DC:E7:29:26 in vlan 131
is flapping between port Gi5/5 and port Gi5/4
Aug 18 11:57:26.925: %C4K_EBM-4-HOSTFLAPPING: Host 00:10:DC:E7:29:26 in vlan 131
Aug 18 11:57:26.953: %C4K_EBM-4-HOSTFLAPPING: Host 00:10:DC:E7:29:26 in vlan 131
is flapping between port Gi5/4 and port Gi5/5
Aug 18 11:57:27.001: %C4K_EBM-4-HOSTFLAPPING: Host 00:10:DC:E7:29:26 in vlan 131
Aug 18 11:57:27.125: %C4K_EBM-4-HOSTFLAPPING: Host 00:10:DC:E7:29:26 in vlan 131
Aug 18 11:57:27.541: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 10.4.255.1
08 on interface Loopback0
Aug 18 11:57:27.545: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 10.4.100.2
01 on interface GigabitEthernet1/1
06 on interface GigabitEthernet2/1
Aug 18 11:57:27.549: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 10.4.131.2
on interface Vlan131
Aug 18 11:57:27.601: %PIM-5-NBRCHG: neighbor 10.4.100.205 UP on interface Gigabi
tEthernet2/1
Aug 18 11:57:27.601: %PIM-5-NBRCHG: neighbor 10.4.100.202 UP on interface Gigabi
tEthernet1/1
Aug 18 11:57:27.609: %PIM-5-DRCHG: DR change from neighbor 10.4.100.201 to 10.4.
100.202 on interface GigabitEthernet1/1
Aug 18 11:57:27.693: %OSPF-5-ADJCHG: Process 100, Nbr 10.4.255.106 on GigabitEth
ernet1/1 from LOADING to FULL, Loading Done
Aug 18 11:57:28.809: %OSPF-5-ADJCHG: Process 30, Nbr 10.4.247.13 on GigabitEther
net2/2 from LOADING to FULL, Loading Done
Aug 18 11:57:28.949: %OSPF-5-ADJCHG: Process 100, Nbr 10.4.255.109 on GigabitEth
ernet2/1 from LOADING to FULL, Loading Done
Aug 18 11:57:33.129: %OSPF-5-ADJCHG: Process 30, Nbr 10.4.247.5 on GigabitEthern
et1/2 from LOADING to FULL, Loading Done
Aug 18 11:58:57.576: %C4K_REDUNDANCY-6-DUPLEX_MODE: The peer Supervisor has been
detected
Aug 18 11:59:04.267: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 1 (WS-X4516 S/N:
JAE11441SCD Hw: 4.4) is online
Aug 18 11:59:04.275: %C4K_REDUNDANCY-6-MODE: ACTIVE supervisor initializing for
sso mode
Aug 18 11:59:04.583: %C4K_REDUNDANCY-3-COMMUNICATION: Communication with the pee
r Supervisor has been established
Aug 18 11:59:09.691: %C4K_REDUNDANCY-5-CONFIGSYNC: The bootvar has been successf
ully synchronized to the standby supervisor
Aug 18 11:59:09.691: %C4K_REDUNDANCY-5-CONFIGSYNC: The config-reg has been succe
ssfully synchronized to the standby supervisor
Aug 18 11:59:09.691: %C4K_REDUNDANCY-5-CALENDAR: The calendar has been successfu
lly synchronized to the standby supervisor for the first time
Aug 18 11:59:09.691: %C4K_REDUNDANCY-5-CONFIGSYNC: The startup-config has been s
uccessfully synchronized to the standby supervisor
Aug 18 11:59:09.867: %C4K_REDUNDANCY-5-CONFIGSYNC: The private-config has been s
Aug 18 11:59:10.487: %C4K_REDUNDANCY-5-CONFIGSYNC_RATELIMIT: The vlan database h
as been successfully synchronized to the standby supervisor
Aug 18 11:59:31.767: %HA_CONFIG_SYNC-6-BULK_CFGSYNC_SUCCEED: Bulk Sync succeeded
Aug 18 11:59:31.851: %RF-5-RF_TERMINAL_STATE: Terminal state reached for (SSO)
RRTF_4507#
Rollin Kibbe
Hi deepaks_1974:
I'm not sure what an "upgradation" is, but this doesn't look to be a Network Management question, but instead a LAN switching question.
The Catalyst 4500 System Message Guide shows:
http://tools.cisco.com/squish/13AaD
Error Message    C4K_REDUNDANCY-4-KEEPALIVE_WARNING: Keepalive messages from peer Supervisor are  missing for [dec] seconds
Explanation    Keepalive messages have not been sent from the peer supervisor engine. If the situation persists and the keepalive messages do not resume, the peer supervisor engine will eventually be reset. This message is logged for every third missed keepalive message.
Recommended Action    This is an informational message only. No action is required.
Reposting to the LAN Switching area will get you in touch with folks with more experience in these type things.
Sincerely,
Rollin Kibbe
Network Management Systems Team
Thanks for kind support.
Thanks & Regards,
Deepak Saindane
(M) :  09924140557
