Voice trunk between two UC520
pbaleshenko
Hello.
SMB has two offices in the neighbournig buildings.
Each office has internet access and POTS line. We want to build IP-telephony in both offices and between them.
I'm going to install UC520 in each office and use it as Internet-router and IP-telephony gateway with CME.
I have the following question. I need to configure SIP/H.323 trunk between two UC520. Can I set the trunk between two UC520 if:
1) I connect them with leased line on LAN ports?
2) I connect them with IPSec tunnel?
Thanks in advance
Best regards,
   Pavel
Brandon Buffin
Yes, you can use either option. You will simply create dial peers on each UC520 to handle the calls such as:
Site 1
dial-peer voice 1 voip
destination-pattern 3...
session target ipv4:1.1.1.1
dial-peer voice 2 voip
incoming called-number 4...
Site 2
destination-pattern 4...
session target ipv4:2.2.2.2
incoming called-number 3...
Hope this helps.
Brandon
Brandon Buffin
Site 1
Site 2
Hope this helps.
Brandon
Thanks Brandon!
