Max wireless user limit on Cisco 877W router
Aug 18th, 2010
Hi All,
I am using Cisco 877W to provide wired and wireless conectivity to my users. We are having issues with the router refusing wireless connections after a certain number (most likely technical restraints), because the physical infrastructure is fine e.g. correct SSID passcode and separate frequency channel from anything else in the surrounding area.
If I disconnect one user using wireless, I can then connect another. Any idea about this issue?
Thank you in advance for any assistance.
Mudassar
Leo Laohoo Wed, 08/18/2010 - 05:01
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Can you post the output for the command "sh run ssid "?
mudassar.khan Wed, 08/18/2010 - 05:13
Thanks for your reply. I just for more information I have found on the Cisco documentation that 877W has "configurable limit for wireless clients" so I have increased the "max-associations" limit from 10 to 25. (You can see in the following configuration as requested).
I am troubleshooting this router remotely and they don't have enough clients to test if any difference after this change.
What do you think does it help or I have make any other changes in addition to this?
Many thanks,
Mudassar
sh run ssid V1K1NG
Building configuration...
Current configuration:
dot11 ssid V1K1NG
   vlan 1
   max-associations 25
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 0 h3r5h4mB0y5
end
Leo Laohoo Wed, 08/18/2010 - 05:20
  • Hall of Fame,
    2017 LAN, Wireless
max-associations 25
That's your culprit.
Leo Laohoo Wed, 08/18/2010 - 15:08
  • Hall of Fame,
    2017 LAN, Wireless
I have no idea what you are trying to do nor do I have idea what your network is like, however, I would just like to let you know that an 870 router can push approximately 12.80 Mbps of un-encrypted data.  If you have around 25 users associated to the wireless LAN then the bottle-neck to your WLAN will be your router.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
