ACE URL redirect with Host Header-Value
Aug 18th, 2010
Hi !
My host header class map
class-map type http loadbalance match-all REDIRECT
  2 match http header Host header-value "www.xxx.org"
does not match even i find the host header www.xxx.org in http fox host header field ?
Any suggestions ?
kr
jlamousn Wed, 08/18/2010 - 06:17
Interesting.  We would need to know more about your config and this may require more involved troubleshooting by Cisco Tac.  The class-map configuration is fine since it works on my setup.
Joel Lamousnery
TAC Customer Support Engineer
bsbanksysteme Wed, 08/18/2010 - 06:32
Hi !
Thanks for your comment.
Can you give me some troubleshooting hints for the moment ?
kr
jlamousn Wed, 08/18/2010 - 07:12
Assuming the rest of the config is correct, which I don't have the rest of your config.  You can check "show stats http"  check to see if static parse or max parse length errors are incrementing when you connect to the vip, if the ace run into any of these errors then it would not able to do any layer 7 function like matching that host header.
Joel Lamousnery
bsbanksysteme Wed, 08/18/2010 - 07:20
Hi !
I
We connect with xxx.org in our browser on which address we do a ssl offload and layer 7 loadbalancing.
This works very good.
Now we would need a redirection when we enter www.xxx.org in the browser to the xxx.org L7 LB.
DNS ist working for xxx.org and www.xxx.org (both to the same ip)
Can you help me with a config example ?
I cannot put my config in because off the names and IP addresses.
kr
jlamousn Thu, 08/19/2010 - 05:37
kr,
Here is a sample config
class-map match-all WEB_VIP
  2 match virtual-address 10.10.10.10 tcp eq www
class-map type http loadbalance match-all www
class-map type http loadbalance match-all www1
  2 match http header Host header-value "www1.xxx.org"
policy-map type loadbalance first-match WEB
  class www
    serverfarm Farm1
  class www1
    serverfarm Farm2
  class class-default
    serverfarm Farm3
policy-map multi-match WEB
  class WEB_VIP
    loadbalance vip inservice
    loadbalance WEB
    loadbalance vip icmp-reply active
As I previously stated, you may need to open a tac case for more advanced troubleshooting.
Joel Lamousnery
bsbanksysteme Mon, 08/23/2010 - 06:36
Hi !
Done, but getting errors:
LB parse result msgs sent : 10         , TCP data msgs sent       : 0
Inspect parse result msgs : 0          , SSL data msgs sent       : 0
                      sent
TCP fin msgs sent         : 0          , TCP rst msgs sent:       : 0
Bounced fin msgs sent     : 0          , Bounced rst msgs sent:   : 0
SSL fin msgs sent         : 0          , SSL rst msgs sent:       : 0
Drain msgs sent           : 0          , Particles read           : 10
Reuse msgs sent           : 0          , HTTP requests            : 10
Reproxied requests        : 0          , Headers removed          : 0
Headers inserted          : 0          , HTTP redirects           : 0
HTTP chunks               : 0          , Pipelined requests       : 0
HTTP unproxy conns        : 0          , Pipeline flushes         : 0
Whitespace appends        : 0          , Second pass parsing      : 0
Response entries recycled : 0          , Analysis errors          : 0
Header insert errors      : 0          , Max parselen errors      : 0
Static parse errors       : 10         , Resource errors          : 0
Invalid path errors       : 0          , Bad HTTP version errors  : 0
Headers rewritten         : 0          , Header rewrite errors    : 0
Unproxy msgs sent         : 0
class: CLASS-MAP-REDIRECT-www
     VIP Address:    Protocol:  Port:
     192.xxxxxx   tcp        eq    443
     192.xxxxxxx  tcp        eq    80
      loadbalance:
        L7 loadbalance policy: WWW
        VIP Route Metric     : 77
        VIP Route Advertise  : DISABLED
        VIP ICMP Reply       : ENABLED
        VIP state: OUTOFSERVICE
        curr conns       : 0         , hit count        : 20
        dropped conns    : 20
        client pkt count : 60        , client byte count: 5250
        server pkt count : 0         , server byte count: 0
        conn-rate-limit      : 0         , drop-count : 0
        bandwidth-rate-limit : 0         , drop-count : 0
        L7 Loadbalance policy : WWW
          class/match : WWW
            LB action: :
               primary serverfarm: REDIRECT-SERVERS-WWW
                    state: DOWN
                  backup serverfarm : -
            hit count        : 0
            dropped conns    : 0
Any suggestions ?
Get no rdirect
bsbanksysteme Tue, 08/24/2010 - 00:10
Hi !
works now.
No connection drop anymore.
Must be some configuration error. Can´t exactly tell anymore.
fixed it with host header-value "www.*"
Thanks for ya help
tkitzky Sun, 10/10/2010 - 15:43
For future reference... the problem is that you are not escaping the periods in the regex expression in your class-map. Periods in regex are not just periods, they have special meaning so need to be "escaped" in order to escape their special meaning within the regex. Anyway... you should learn regex a little before getting too involved with these layer-7 class-maps.
Try this to match a specific Host header value.
class-map type http loadbalance match-all WWW.EXAMPLE.COM
  2 match http header Host header-value "www[.]example[.]com"
class-map type http loadbalance match-all IMAGES.ANOTHER-EXAMPLE.COM
  2 match http header Host header-value "images[.]another-example[.]com
