Group Password vpn3000
athukral Wed, 08/18/2010 - 07:54
  • Silver, 250 points or more
Hello Jose!
Hope you must be doing fine!
Here is the way to retrieve the group/user passwords from your VPN Concentrator:
1- Go to 'Administration| Access Rights | Access Settings' and make sure you
select "None" under "Config File Encryption".
2- Go to 'Administration | File Management | XML Export' and select a name
for the XML file. This will export your running configuration into a XML
file, which can be retrieved in the "File Management" tab.
Open the XML file and search for the group name, you will find a field with
the unencrypted password.
NOTE: Please don't forget to set back the access setting to its previous
configuration in case you want to set it back to it's original settings:
Go to -- > Administration | Access Rights | Access Settings-- > Config File
Encryption and select RC4 Select configuration file encryption, Apply and
Save
Let me know how it goes.
Ankur
Dave Randolph Fri, 08/20/2010 - 08:10
Hi Ankur!
Thanks much for your information. Worked like a good charm for me.
Dave
athukral Fri, 08/20/2010 - 17:32
Hello Dave,
I am glad that it worked for you!!
Please feel free to contact in case you need any assistance in fututre.
Wish you a great weekend ahead!
Ankur
Related Content
