CUPM 2.1 8961 and 9951 phones not orderable?
Aug 18th, 2010
I have a starnge problem with my CUPM 2.1 installation (Upgrade 1.3.1 -> 2.0 -> 2.1) and a CUCM 7.1(3) cluster. I added the new phones, 6961, 8961, 9951 and 9971 to the Subscriber Role Configuration. I have a Sevice Area for SCCP and for SIP phones. The 6961 shows up in the SCCP SA order options but in the SIP SA order options, only the 9971 is available. Does anyone know why the Cisco 8961 and 9951 phones are not showing up in the list of orderable phone devices?
Matthew Kaufman Tue, 08/24/2010 - 05:49
  • Cisco Employee,
Hi Max,
I have been looking into this issue after seeing your post yesterday.  I have been unable to find an answer.  I would recommend opening a TAC case so that we can investigate further.
Let me know when you get it open in a private message and I will see if I can grab it and work with you.
--Matt
Max Schmid Wed, 09/29/2010 - 23:09
The problem seems to be found.
CUPM 2.1 only supports the 8961 and 9951 phones when the Call Processor (Communications Manager) is at least version 8.0(1) or higher. Up to 7.1(5) only the 9971 seems to be supported.
