08-18-2010 06:01 AM - edited 03-16-2019 12:18 AM
Can anybody assist with the above? I also need to put a basic config on the BRI card. I think I have it right but not sure.
interface BRI0/3/0
no ip address
isdn switch-type basic-net3
isdn protocol-emulate network
isdn incoming-voice voice
isdn skipsend-idverify
Best Regards,
Paul.
Solved! Go to Solution.
08-18-2010 07:18 AM
It is the very exact same thing, anyway understanding of DPs logic, is key to success.
Please remember to rate useful posts clicking on the stars below.
08-18-2010 06:09 AM
Check your GSM box if it requres PBX to be network-side. It is not said that is the case, or it can have dual interface.
08-18-2010 06:20 AM
Thanks for the quick response. It does not require network side. When i issue a sh voice call summary I see sub interfaces for each of the isdn ports on the card. Is there a config required for each of these interfaces to router the mobile traffic?
A sh isdn status shows the port I have configured as active.
Paul
Sent from my iPhone
08-18-2010 06:57 AM
Then you do not neet to confgiure network side under BRI.
Subinterface on the BRI are never ever configured. Just handle it like any other ISDN interface.
Check however if the GSM box want static TEI in which case configure it.
08-18-2010 06:59 AM
I think where it gets confusing for me is configuring a Dial-peer group for the ports and mobile networks as it seems to be different than creating groups for POTS lines.
Paul.
08-18-2010 07:18 AM
