How to Enable a port after err-disable
Answered Question
Aug 18th, 2010
Hello
I had a port get disabled because of a feedback loop. Plugged it back Iin and cannot re-enabled via CNA
Is there a command to re-enable the port
The document i found suggest using the shut down then no shut down command
Is that safe ? will it kick all ports ?
Cisco Catalyst 3750
Correct Answer by podhillo about 6 years 11 months ago
We can use 'shut' , 'no shut' and we can configure the switch to recover automatically.
Commands are as follows:
errdisable detect cause command 2-140
errdisable detect cause small-frame comand 2-143
errdisable recovery cause small-frame 2-145
errdisable recovery command 2-146
error conditions, displaying 2-469
more details of the commands link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/command/reference/ComRef.html#LTR_E
Hope this helps!
podhillo
Correct Answer by Reza Sharifi about 6 years 11 months ago
Yes, Just do a sh and no sh on that port.  That should enable the port again.
Reza
Overall Rating: 5 (2 ratings)
Correct Answer
Reza Sharifi Wed, 08/18/2010 - 09:41
  • Cisco Designated VIP,
    2017 LAN
Reza
Correct Answer
podhillo Wed, 08/18/2010 - 10:19
  • Bronze, 100 points or more
Hope this helps!
podhillo
