08-18-2010 09:46 AM - edited 03-04-2019 09:28 AM
I am having a problem with a BGP connection in that my local policy appears to be denying almost all prefixes per the followiing excerpt from "sh ip bgp neighbor":
Outbound Inbound
Local Policy Denied Prefixes: -------- -------
route-map: 0 324903
filter-list: 33341167 0
AS_PATH loop: n/a 24
Total: 33341167 324927
Number of NLRIs in the update sent: max 1, min 1
My BGP and route-map configuration is pretty basic, excerpted below. It is the neighbor at remote-as 3356 that should be populating my routing table. The other neighbor is an iBGP peer connected to my other upstream provider.
router bgp 26353
no synchronization
bgp log-neighbor-changes
network 64.94.72.0 mask 255.255.252.0
neighbor 4.79.169.9 remote-as 3356
neighbor 4.79.169.9 description Level3
neighbor 4.79.169.9 version 4
neighbor 4.79.169.9 send-community
neighbor 4.79.169.9 soft-reconfiguration inbound
neighbor 4.79.169.9 route-map BGW01-IN in
neighbor 4.79.169.9 route-map BGW01-OUT out
neighbor 4.79.169.9 filter-list 21 out
neighbor 64.94.72.2 remote-as 26353
neighbor 64.94.72.2 update-source Loopback0
neighbor 64.94.72.2 version 4
neighbor 64.94.72.2 soft-reconfiguration inbound
no auto-summary
route-map BGW01-OUT permit 10
match as-path 21
set community 3356:300
route-map BGW01-IN permit 10
match as-path 23
set local-preference 300
ip bgp-community new-format
ip as-path access-list 21 permit ^$
ip as-path access-list 22 permit .*
ip as-path access-list 23 permit _3356$
Am I missing something basic here?
08-18-2010 10:00 AM
What routes are you trying to learn from this neighbor? Your as-path ACL is matching any prefixes originating from AS 3356. Can you show us some of the output from "show ip bgp neighbor 4.79.169.9 received-routes" ?
Good document with AS-path filtering examples:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800c95bb.shtml#sec3
-Kathy
08-18-2010 10:11 AM
I am getting thousands of routes - the output scrolls for page after page, ending with:
Total number of prefixes 320938
It's more the "local policy denied" entry for inbound prefixes that I am asking about. I don't understand that.
Outbound Inbound
route-map: 0 333990
Since I appear to be geting the routes despite that entry, is it an issue?
08-18-2010 10:22 AM
Outbound Inbound
route-map: 0 333990
This output would mean you are denying that number of routes from being learned because of the route-map configuration:
Are you actually learning all of these routes and putting them in the routing table? The command I mentioned, "show ip bgp neighbor 4.79.169.9 received-routes" shows you a list of every prefix sent by this neighbor. It doesn't show you the prefixes that this router is actually learning. "show ip bgp" will show you routes that you're actually learning. Does it show you these routes are learned from this neighbor? What routes do you want to learn from this neighbor?
08-18-2010 10:32 AM
I want to learn "all" routes (a full table). This is a secondary connection with the primary out a similar path from my iBGP neighbor.
sh ip bgp gives me a long listing beginning with
dc4-bgw-01# sh ip bgp
BGP table version is 542331800, local router ID is 64.94.72.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*>i1.9.0.0/16 66.151.100.85 0 350 0 10913 3561 4788 i
* 4.79.169.9 41 300 0 3356 1273 4788 i
*>i1.11.128.0/17 66.151.100.85 0 350 0 10913 22212 9318 38091 17839 i
* 4.79.169.9 0 300 0 3356 2828 9318 38091 17839 i
*>i1.12.0.0/24 66.151.100.85 0 350 0 10913 1239 4837 4808 17431 18245 i
* 4.79.169.9 0 300 0 3356 1239 4837 4808 17431 18245 i
and ending with
* 223.223.216.0 4.79.169.9 0 300 0 3356 3257 10026 24549 24549 24549 24549 i
*>i 66.151.100.85 0 350 0 10913 22212 10026 24549 24549 24549 24549 i
* 223.240.0.0/13 4.79.169.9 0 300 0 3356 1239 4134 i
*>i 66.151.100.85 0 350 0 10913 174 4134 i
* 223.255.192.0/19 4.79.169.9 753 300 0 3356 15412 9848 9848 9848 9848 9848 9848 9848 9848 9848 9848 9848 9848 9963 i
*>i 66.151.100.85 0 350 0 10913 174 10026 9848 9963 i
dc4-bgw-01#
08-18-2010 10:56 AM
That's strange that you're learning these routes even though they aren't originated from AS 3356. Did you apply this route-map after the neighbor was up? If so, did you do a soft clear on this neighbor? Whenever making changes to the route map for a BGP neighbor, be sure to issue a "clear ip bgp neighbor x.x.x.x soft" for it to take effect. Was this the whole route-map:
match as-path 23
Could you show the output from "show route-map BGW01-IN" and "show ip as-path-access-list" and try the soft clear?
Also if you want to learn all routes from this neighbor, why are you matching the as-path? Do you want to set the local pref to 300 for all routes from this neighbor or only for certain routes? If you want to set it for all routes, you don't need to do "match as-path" at all.
-Kathy
08-18-2010 12:30 PM
With respect to some of the "why" questions, I inherited this config and am just trying to understand why it is working the way it is. My experience with this environment is that there are several configuration aspects that are, strictly speaking, unnecessary but used here as part of a more or less uniform approach to how the previous team had set up peers in many environments. I believe they wanted local pref to be 300 for all routes on this link. (The other router at the site has local pref 350 so all my traffic flows that over route normally.) Personally I'd like to get them set up in more of a load sharing mode so that the traffic flows over both links according to the best path as determined by BGP.
I modified the route-map after bgp has been established in an effor to troubleshoot this problem. I had not used the "clear ip bgp.. " command but have now. Here is the output you asked about:
dc4-bgw-01# clear ip bgp 4.79.169.9 soft
dc4-bgw-01#show route-map BGW01-IN
route-map BGW01-IN, permit, sequence 10
Match clauses:
as-path (as-path filter): 23
Set clauses:
Policy routing matches: 0 packets, 0 bytes
dc4-bgw-01#show ip as-path-access-list
AS path access list 21
permit ^$
AS path access list 22
permit .*
AS path access list 23
permit _3356$
dc4-bgw-01#
Following the clear, I still see the local policy denied prefixes with a high count. Here is the complete "show ip bgp nei 4.79.169.9" output:
dc4-bgw-01#sh ip bgp nei 4.79.169.9
BGP neighbor is 4.79.169.9, remote AS 3356, external link
Description: Level3
BGP version 4, remote router ID 4.68.1.237
BGP state = Established, up for 6w0d
Last read 00:00:06, last write 00:00:17, hold time is 180, keepalive interval is 60 seconds
Neighbor sessions:
1 active, is not multisession capable
Neighbor capabilities:
Route refresh: advertised and received(new)
Address family IPv4 Unicast: advertised and received
Message statistics:
InQ depth is 0
OutQ depth is 0
Sent Rcvd
Opens: 1 1
Notifications: 0 0
Updates: 3 3372595
Keepalives: 55236 61261
Route Refresh: 0 0
Total: 55240 3433857
Default minimum time between advertisement runs is 30 seconds
For address family: IPv4 Unicast
Session: 4.79.169.9
BGP table version 542388466, neighbor version 542388466/0
Output queue size : 0
Index 2, Offset 0, Mask 0x4
2 update-group member
Inbound soft reconfiguration allowed
Community attribute sent to this neighbor
Inbound path policy configured
Outbound path policy configured
Outgoing update AS path filter list is 21
Route map for incoming advertisements is BGW01-IN
Route map for outgoing advertisements is BGW01-OUT
Sent Rcvd
Prefix activity: ---- ----
Prefixes Current: 1 1155 (Consumes 16762980 bytes)
Prefixes Total: 3 10870456
Implicit Withdraw: 2 9867557
Explicit Withdraw: 0 724062
Used as bestpath: n/a 0
Used as multipath: n/a 0
Saved (soft-reconfig): n/a 321210 (Consumes 16702920 bytes)
Outbound Inbound
route-map: 0 992102
filter-list: 34731876 0
Total: 34731876 992126
Address tracking is enabled, the RIB does have a route to 4.79.169.9
Connections established 1; dropped 0
Last reset never
Transport(tcp) path-mtu-discovery is enabled
Connection state is ESTAB, I/O status: 1, unread input bytes: 0
Mininum incoming TTL 0, Outgoing TTL 1
Local host: 4.79.169.10, Local port: 179
Foreign host: 4.79.169.9, Foreign port: 21944
Enqueued packets for retransmit: 0, input: 0 mis-ordered: 0 (0 bytes)
Event Timers (current time is 0xF971FE4F4):
Timer Starts Wakeups Next
Retrans 57381 2141 0x0
TimeWait 0 0 0x0
AckHold 277139 131752 0x0
SendWnd 0 0 0x0
KeepAlive 0 0 0x0
GiveUp 0 0 0x0
PmtuAger 0 0 0x0
DeadWait 0 0 0x0
iss: 3335798635 snduna: 3336848347 sndnxt: 3336848347 sndwnd: 15658
irs: 2926055904 rcvnxt: 3274360305 rcvwnd: 16384 delrcvwnd: 0
SRTT: 301 ms, RTTO: 308 ms, RTV: 7 ms, KRTT: 0 ms
minRTT: 0 ms, maxRTT: 724 ms, ACK hold: 200 ms
Flags: passive open, retransmission timeout, nagle, path mtu capable
gen tcbs
Datagrams (max data segment is 1460 bytes):
Rcvd: 476555 (out of order: 0), with data: 421516, total data bytes: 348304400
Sent: 384265 (retransmit: 2141), with data: 55240, total data bytes: 1049711
dc4-bgw-01#
08-18-2010 01:01 PM
all BGP AS paths coming from AS 3356 have AS 3356 in leftmost position and can be matched with
ip as-path access-list 24 permit ^3356
meaning all AS paths beginning with AS 3356
your current AS path access-list looks for AS paths where 3356 is inside the AS path not in first position
so you could match only routes where AS 3356 appears more then one time (prepended)
Edit:
if level3 is an upstream provider providing full table you should simply deny private IP addresses as a security measures and the bogus networks and accept all other. You may think of using a control on the number of prefixes you receive with warning option
Hope to help
Giuseppe
08-18-2010 01:57 PM
Thank you for your input, Giuseppe. I have modified my as-path filter according to your suggestion. That did not seem to help the issue I am seeing. So I took the additional step of changing the reference in my incoming route-map to point intead to as-path 22 which is a permit .* regexp and should thus allow all prefixes. I still see inbound routes denied by the route map according to the "sh ip bgp nei 4.79.169.9" output.
Here is the current setup:
dc4-bgw-01#sh route-map
route-map BGW01-OUT, permit, sequence 10
Match clauses:
as-path (as-path filter): 21
Set clauses:
community 3356:300
route-map BGW02-OUT, permit, sequence 10
Match clauses:
Set clauses:
community 10913:300
Match clauses:
as-path (as-path filter): 22
Set clauses:
route-map BGW02-IN, permit, sequence 10
Match clauses:
Set clauses:
local-preference 350
dc4-bgw-01#sh ip as-path
permit ^$
permit .*
permit ^3356
Description: Level3
Last read 00:00:09, last write 00:00:27, hold time is 180, keepalive interval is 60 seconds
Neighbor sessions:
Message statistics:
InQ depth is 0
OutQ depth is 0
Sent Rcvd
Opens: 1 1
Notifications: 0 0
Updates: 9 3375752
Keepalives: 55315 61351
Route Refresh: 0 0
Total: 55325 3437104
Session: 4.79.169.9
BGP table version 542436641, neighbor version 542436581/0
Sent Rcvd
Prefixes Current: 1 321248 (Consumes 33409792 bytes)
Prefixes Total: 9 10874956
Implicit Withdraw: 8 9871768
Explicit Withdraw: 0 724337
Saved (soft-reconfig): n/a 321248 (Consumes 16704896 bytes)
Outbound Inbound
route-map: 0 1959188
filter-list: 36748157 0
Total: 36748157 1959212
Last reset never
Event Timers (current time is 0xF97728E30):
Retrans 57470 2145 0x0
TimeWait 0 0 0x0
AckHold 277483 131940 0x0
SendWnd 0 0 0x0
KeepAlive 0 0 0x0
GiveUp 0 0 0x0
PmtuAger 0 0 0x0
DeadWait 0 0 0x0
iss: 3335798635 snduna: 3336850202 sndnxt: 3336850202 sndwnd: 15270
irs: 2926055904 rcvnxt: 3274674919 rcvwnd: 16384 delrcvwnd: 0
SRTT: 300 ms, RTTO: 303 ms, RTV: 3 ms, KRTT: 0 ms
gen tcbs
Rcvd: 477106 (out of order: 0), with data: 421985, total data bytes: 348619014
Sent: 384706 (retransmit: 2145), with data: 55325, total data bytes: 1051566
dc4-bgw-01#
08-18-2010 11:37 PM
as the Internet Looking Glass servers are showing cca 340 000 prefixes within the Internet, I believe your router is accepting all prefixes from the neighbor now, as your output is showing:
Session: 4.79.169.9
Sent Rcvd
And the counters below might have NOT been cleared by clear ip bgp ... soft command?
Outbound Inbound
Can you provide sh ip bgp sum
to check how many prefixes are you receiving from your neighbor?
ad the original route-map)
is matching prefixes originated from your neighbor AS.
So there might have been an idea: Let's give local preference 300 to the prefixes originated by the neighbor itself and accept all other prefixes with the default local preference?
In that case, just a line
route-map BGW01-IN permit 20
might be missing?
The complete route-map would look:
match as-path 23
What do you think about this possibility?
HTH,
Milan
08-19-2010 08:49 AM
Hello all,
Milan is right:
the original intention can be that of providing better local preference to routes with AS path = ^3556$, so you need a second route-map clause to permit all other prefixes as noted
I had missed this point.
Hope to help
Giuseppe
