WLC 4402, LAP1242AG APs and Layer 2 Switch Network Design
Answered Question
Aug 18th, 2010
Hi Every One,
I am new designer in the Wireless technology. During design i came accros through a confusing/complex existing topology which i have to integrate with WLC 4402 as below;
Existing:
1: I have 12 Switches; all vtp mode server. all in single vlan 1 with single subnet 192.168.0.0/24. All users ports in this single vlan 1.
2: All of these are old switches including 2950G, 350GXL, 4912.
3: All the switches gateway is Pix Firewall (192.168.0.1).
To Do:
1: I have to implement 1 * WLC 4402, 22 *LAP1242AG Access Points.
2: WLC will be connected to 350GXL or 4912 through Fiber.
3: Access Points will be connected to all other 20 switches randomely.
Confusion:
1: In my design i created separate vlan 450 for WLC and APs management. But this is not doable in this current setup because all the switches are vtp mode server. Also the gateway is Firewall. Which will require configuration on all existing switches + Pix.(I DONT WANT TO GO FOR THIS OPTION).
2: To make my work easy, is this possible to Put the WLC, APs in the same vlan 1 (192.168.0.0/24) that is currently used by the existing switches? The gateway for these WLC and APs will be Pix (192.168.0.1).
3: I tried to search Cisco examples, but in every example Cisco has made a separate vlan for WLC, APs management. So will Point 2 worK?
4: Do i require any specific changes for this?
5: ANY OTHER DESIGN SUGGESTION?????????
Please find the attached Diagram for more information.
Correct Answer by Leo Laohoo about 6 years 7 months ago
I also have to check vtp pass??
To check if you have VTP password, use the command "sh vtp password".
Wat do u mean by vtp config
VTP config isn't going to affect your WLC/WLAN in general.
Your configuration should work.
Overall Rating: 5 (1 ratings)
Leo Laohoo Wed, 08/18/2010 - 15:25
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
It would work.  If that is the case then configure the WLC Management IP Address as VLAN "0" (or untagged) and the switchport to be an access port.
Regarding VTP mode Server, make sure you didn't configure the VTP domain and/or the VTP password.
ABDUL MAJID KHAN Fri, 08/20/2010 - 14:33
Thanks for the reply.
1: U mean dat the switch port config will be as below;
int g0/10
description connected to WLAN Controller
switch mode access
switch access vlan 1
int g0/23
description connected to AP
switchport mode access
switchport access vlan 1
so below wil b the sumary of config:
All switches, WLC, APs, Wireless users and Wired users will be in the same subnet (192.168.0.0/24). Is it ok??
2: Wat do u mean by vtp config; Please clarify???
As i mentioned all switches are in vtp mode server. vtp domain name is configred on 12 out of 15 switch. Do i need to config same vtp domain name on all switches? I also have to check vtp pass??
Correct Answer
Leo Laohoo Fri, 08/20/2010 - 18:05
  • Hall of Fame,
    2017 LAN, Wireless
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
