Interface for WLAN issue
Aug 18th, 2010
We are replacing a WLC4402 with a WLC 5508. Both controllers are running 7.0.98 software. The WLANs we had defined on the 4402 didn't have an IP address on the WLC interface. We used 0.0.0.0 and entered the VLAN it was to operate on.
When I setup the WLAN on the 5508. I created the interface with the 0.0.0.0. It whined a bit on that saying no gateway or mask but it created it. When I setup the WLAN and try to assign it to the interface I get an error. Error setting the interface name. It seems like the error checking in 7.X code is preventing me from doing this. The 4402 had these interfaces and WLAN defined prior to upgrading to 7.0.98.
The VLANs the WLAN are running on are just a pipe to another network we don't manage. I have no IP to set on the interface. If I can't enter 0.0.0.0. What should I use?
Craig
Trending Topics - Security & Network
