Manual DHCP bindings
Answered Question
Aug 18th, 2010
Using Layer3 switch C3750 12.2(53) IOS I can dynamically assign IP configs to MS XP laptops with the DHCP service but I cannot statically assign host IP using the MAC address. I have tried both client-id (catenating using the 01 prefix) and by hardware ieee802 and the default Ethernet. with no success -looking for suggestions. Thanks
Should also mention on the client laptop user privileges are very restricted and network configurations cannot be changed so the router DHCP service must accommodate
Correct Answer by kyukim about 6 years 11 months ago
Manual DHCP binding should work fine with below config example.
ip dhcp pool Mars
 host 172.16.2.254 mask 255.255.255.0
 hardware-address 02c7.f800.0422 ieee802
 client-name Mars
If you configured as same as above example and it is still not working, you can check why it is not working by "deb ip dhcp server packet" and "deb ip dhcp server event".
These two debug will tell you how 3750 received DHCP discover from PC and how it respond to it.
If you copy the output of above debug, I can review it.
Also, what IOS version are running on it?
KK.
Overall Rating: 5 (1 ratings)
Correct Answer
kyukim Wed, 08/18/2010 - 15:32
  • Cisco Employee,
ip dhcp pool Mars
 client-name Mars
KK.
bryantsteve Thu, 08/19/2010 - 09:55
Thank you Kim, including the  client-name with the laptop's assigned name works
