CCNA Lab Setup
Aug 18th, 2010
If there are any network pros out there can someone give me your thoughts on these lab setups for ccna prep?
Lab 1
Routers:
2x Cisco 2610 w/ 12.3.26 IOS (Absolute top of the line IOS for this model) 2x WIC-1T (Providing the first Serial Interface on each 2610 Router) 2x WIC-1DSU-T1 (Providing the second Serial Interface on each 2610 Router)
Switches:
2x Cisco WS-C2924-XL-EN Enterprise Enhanced IOS Software
Cables:
1x Cat5 T-1 Serial Crossover Cable
1x DTE/DCE Serial Crossover Cable
3x Ethernet straight-thru cables to connect your LAN to the various lab networks as per Cisco Academy Labs
2x Ethernet crossover cables to be used for VLAN Trunking between switches as well as router to router connections
4x Power Cords
1x Console cable DB9 to RJ45
Lab 2
  1. Two Cisco 2600 Series 2610 Routers having minimum 8MB Flash, 1 Ethernet port, 2 Serial ports
  2. Two Cisco 3500 Series Switches 3524-XL having 24 Fast Ethernet, 2 Gigabit Interfaces
  3. 2 Back to Back Serial Cables to connect Routers
  4. 1 Console Cable to configure the Routers and Switch
  5. 4 Power Cables
Related Content
