Switching
Get 20% off switches when you combine Cisco solutions
Labels
Hey, i am working on a project And I have problems with my DHCP server. I don't remember how it came about. Hence I am asking here. I don't understand why my laptops at the bottom are not getting ip? Anyone who can help me. Packet tracer + Network di...
TS40 by Level 1
  • 71 Views
  • 1 replies
Hi, Do you have been happen this logging show that, and there are none any effect to our netwoek bunisness. im client 'chasfs' has taken 332 msec (runtime: 332 msec) to process a 'stack chasfs fd' messageMar 28 23:25:32.568: %IOSXE_INFRA-6-PROCPATH_C...
hansons by Level 1
  • 75 Views
  • 1 replies
Hello, I can't manage to give the connected PCs an ip through the dhcp server. My packet tracer + network design are attached. Have currently only started on the bottom part so it's only about the bottom PCs.Thanks in advance for the effort
TS40 by Level 1
  • 117 Views
  • 1 replies
I am trying to configure a trunk port on a Cisco 3750 that has fiber running to a ruckus 7150 switch.My current config connects the switches but it is only passing vlan1 traffic and I want multiple vlans. Therefore, I configured the port as a trunk o...
oowJ by Level 1
  • 172 Views
  • 4 replies
Hello everyone!I'm not a network engineer but as a subsystem (kernel + filesystem) engineer I know the network concept.Few months ago, I designed a DMZ and configured my 2 node VPC with 6 rack switch.Everything was smoothly working but I started to s...
Ozy by Level 1
  • 107 Views
  • 1 replies
On Nexus 7000s I want to limit bandwidth of particular IP. I can do this using proper configuratio of IP ACL, policy map and class map. But what if I dont have information on interface?  Can I apply bandwidth control for particular IP without knowing...
liveshell by Level 1
  • 952 Views
  • 5 replies
I have a less then a dozen Cisco 3850 switches that I am working on.  I need to configure 802.1x authentication.  The issue is the switches are reaching out to Cisco ACS and I need to set up radius server to enable 802.1x.  The Cisco ACS I found out ...
John N by Level 1
  • 224 Views
  • 6 replies
Am trying to create a new local account on a Nexus 3048 so I can SSH to it if my Radius server doesn't work.  Normally, I log in with my AD account which the switch uses Radius for authentication with that.  However, when I run the command to create ...
mramj499 by Level 1
  • 74 Views
  • 1 replies
Dear community I am getting into NetFlow a little bit deeper but cannot get my head around sampling. All i understand so far: We can configure deterministic sampling, that uses a hardware sampler per interface, limiting the maximum number of monitori...
