HSRP between routers
Answered Question
Aug 18th, 2010
   I have two routers with 3 fastethernet interfaces.one interface will be connected to internet and other will be connected to firewall(active/standby).Is it possible to configure HSRP between two routers.
Thanks in advance
Anvar
Correct Answer by KARUPPUCHAMY MA... about 6 years 10 months ago
Yes.You can.
But the better way is to connect is
router A  -----------L2 switch ----- Primary Firewall
Router B------------ L2 Switch ---- Secondary Firewall.
Either you can use, single L2 or 2xL2.
Samy
Overall Rating: 5 (1 ratings)
KARUPPUCHAMY MA... Wed, 08/18/2010 - 23:14
  • Silver, 250 points or more
You need to have Layer 2 communication device in between these routers to share the HSRP messages.Initial stage these hsrp message will use to identify who are all in the same HSRP group.Later it is used to check the availability of active router.
Based on your configuration, One rotuer act as active and another one will be standby
The router are in the same HSRP group has to share their interface details with its virtual mac address.so if you dont have any layer 2 communication device, the virtual mac address cannot share to the routers.
For more information have a look into the below url
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094afd.shtml
Samy
anva12345 Thu, 08/19/2010 - 00:06
Hi samy
  Thanks very much for the information.Can i use the third interface
Correct Answer
KARUPPUCHAMY MA... Thu, 08/19/2010 - 00:15
Yes.You can.
Samy
