Which USB Flash Keys are supported?
Aug 18th, 2010
I was looking for the USB compatibility matrix in this document: http://www.cisco.com/en/US/docs/video/digital_media_systems/dms_compat.html
and i can see that is not updated ( latest version in the document is 5.1)
Are you aware of any updated version of this document?
In addition, i 'm mostly interested on the usb flash keys i can use in v5.2 . Have you tried any apart from the ones in the compatibility table?
Thanking you
Tomas De Leon Fri, 08/20/2010 - 13:37
  • Cisco Employee,
AFAIK, there is not an updated list of USB drives that have been tested with
the 5.2.x releases.   There are so many vendors & models of USB drives that
we can not possibly test them all and validate them.  The List that you mention
in the Matrix URL link is a good reference to follow for 5.2.  If you stay with the
listed manufacturers list & brand names, You "should" be ok, but the only true
test is using it first hand.
I would suggest that you purchase the USB Drive of preference and test a single
DMP-4400 & DMP-4305G to verify successful operation.  Once verified, then you
can purchase additional drives for your desired deployment.
Cheers!
T.
Related Content
