SIP Phones - re-registration issues
Rajesh Kongath
Dear Community,
My CUCME new SIP phones are restarting and re-registering in everything 5 minutes, SCCP phone are working fine. I have done all basic configuration required to register and activate SIP phones (CUBE config, Voice register global config, mapped dns to buttons etc), while doing "debug ccsip errors" i am getting the following messages
BRANCH2-R3#sh ip int b
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            172.16.120.2    YES NVRAM  up                    up
FastEthernet0/1            unassigned      YES NVRAM  administratively down down
Serial0/0/0                unassigned      YES NVRAM  administratively down down
Serial0/0/1                unassigned      YES NVRAM  administratively down down
Serial0/1/0:0              unassigned      YES unset  down                  down
Serial0/1/0:1              unassigned      YES unset  down                  down
Serial0/1/0:2              unassigned      YES unset  down                  down
Serial0/1/0:15             unassigned      YES unset  down                  down
Loopback0                  3.3.3.3         YES NVRAM  up                    up
BRANCH2-R3#sh run | se voice register global
mode cme
source-address 3.3.3.3 port 5060
max-dn 10
max-pool 5
load 7961 SIP41.8-4-2S
authenticate register
tftp-path flash:
create profile sync 0004223125212201
BRANCH2-R3#
Aug 18 23:26:27.912: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:26:27.912: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:26:27.912: //91/DBFCA6598064/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
Aug 18 23:27:12.189: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:27:12.189: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:27:12.189: //92/F660E1AE8065/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization head
Aug 18 23:27:47.706: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:27:47.706: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:27:47.706: //93/0B8C3DC18066/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
Aug 18 23:27:47.730: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:27:47.730: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:27:47.734: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_delete_from_mac_table: RCB with mac [001b53b89ce4] has been removed
Aug 18 23:27:47.734: //-1/xxxxxxxxxxxx/SIP/Error/check_supported_header_for_matching_tag: Unable to access supported header values
Aug 18 23:30:16.519: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:30:16.523: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:30:16.523: //94/643FEC9F8067/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
Aug 18 23:31:00.971: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:31:00.975: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:31:00.975: //95/7EBEDAD48068/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
Aug 18 23:31:36.455: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:31:36.455: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:31:36.455: //96/93E4A01A8069/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
Aug 18 23:31:36.483: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:31:36.483: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:31:36.483: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_delete_from_mac_table: RCB with mac [001b53b89ce4] has been removed
Aug 18 23:31:36.487: //-1/xxxxxxxxxxxx/SIP/Error/check_supported_header_for_matching_tag: Unable to access supported header values
Aug 18 23:34:13.578: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:34:13.578: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:34:13.578: //97/F18BA65B806A/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
Aug 18 23:34:58.118: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:34:58.118: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:34:58.118: //98/0C17E568806B/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
Aug 18 23:35:33.597: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:35:33.601: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:35:33.601: //99/213E28CD806C/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
Aug 18 23:35:33.629: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
Aug 18 23:35:33.629: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
Aug 18 23:35:33.629: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_delete_from_mac_table: RCB with mac [001b53b89ce4] has been removed
Aug 18 23:35:33.629: //-1/xxxxxxxxxxxx/SIP/Error/check_supported_header_for_matching_tag: Unable to access supported header values
Thanks in advance
rajesh
paolo bevilacqua
Do not use SIP for Cisco phones with CME.
Use SCCP and everything will work smooth, plus you will have much more features and a better calling experience.
Thanks for the response, i need to do SIP for my lab requirements
dear community  :Any other comments
hi i have the same problem but some of SIP Phones are registered while others not .
i ran the same debug and i am receiving the same error .
so would you advice if you got any chance to solve it .
