Can't seem to assign a number to the mwi On and mwi Off?"
Aug 19th, 2010
I cant seem to assign a number to the mwi on and mwi off? Does anyone know how to get arround this? Would appreciate your input. thks
Running IOS 124-24.T3 CME 7.1 & CUE 7.1.7 the configuration as as per below.
Based on the CUE config, i also tried creating the two extension
8000 and 8001 under "Configure >> Extensions". Did a number MWI refresh but no changes.
ccn application ciscomwiapplication aa
description "ciscomwiapplication"
enabled
maxsessions 6
script "setmwi.aef"
parameter "CallControlGroupID" "0"
parameter "strMWI_OFF_DN" "8001"
parameter "strMWI_ON_DN" "8000"
end application
From the voice Mail > Message waiting indicators > settings,  i get this
OUTCALLING
MWI On NUmber <No MWI on NUmber Defined on CCME>
MWI On NUmber <No MWI off NUmber Defined on CCME>
From CUE  Administration > Synchronize information, i get the below infor:
The following configuration on the CME and CUE is unsynchronized -
Synchronize MWI On number
  8000 is not a valid MWI On number on CME. Create a new MWI On number on CME.
Synchronize MWI Off number
  8001 is not a valid MWI Off number on CME. Create a new MWI Off number on CME.
lpoon Thu, 08/19/2010 - 01:05
FYI, Guys, Worked it out defined extension as 8001.... & 8001....
paolo bevilacqua Thu, 08/19/2010 - 01:20
  • Hall of Fame,
    Founding Member
Do not bother assigning these numbers.
Use "unsolicited notify" MWI method, it is simple and works well.
