How to configure IOS firewall to open webserver.
Answered Question
Aug 19th, 2010
Hi everyone,
I would like to configure a router,
1. My ISP provides a global IP address with PPPoE. ex) 200.200.200.2 .
2. The router used in this scenario is 2611XM with IOS 12.4T(AES) which has two FastEthernet interfaces, Fa0/0 and Fa0/1.
3. I would like to open a HttpServer to public internet.
4. Some clients access to public internet by PAT.
like a following figure.
Could you tell me the basic story or the documentation's url to configure this scinario?
Tomoyuki
Correct Answer by Nagaraja Thanthry about 6 years 7 months ago
Please check the configuration below. I am assuming you are using
sub-interfaces to configure DMZ and inside:
int fa 0/0.1
description inside
ip address
        • Dynamic NAT for inside clients*************
ip nat source list 1 interface fastethernet 0/1 overload
        • Static NAT for webserver ******************
ip nat source static tcp 198.132.219.1 80 interface fastethernet 0/1 80
access-list 199 permit tcp any
interface fa 0/1
ip access-group 199 in
exit
I noticed that the webserver IP in the DMZ is public IP. If you own that
public IP, then you do not need the static translation. You can change the
access-list entry accordingly.
Hope this helps.
NT
Correct Answer by KARUPPUCHAMY MA... about 6 years 7 months ago
Not a big deal to configure cisco IOS firewall.
Just go through the below URL and hope it will help you to configure your router.
http://www.cisco.com/en/US/products/sw/secursw/ps1018/prod_configuration_examples_list.html#anchor2
Samy
Overall Rating: 5 (2 ratings)
Correct Answer
Nagaraja Thanthry Thu, 08/19/2010 - 06:29
  • Cisco Employee,
int fa 0/0.1
description inside
ip address
interface fa 0/1
exit
Hope this helps.
NT
cisco_fun_4899 Wed, 08/25/2010 - 01:38
Thank you for your good help!
I got it. I'll try it soon.
> I noticed that the webserver IP in the DMZ is public IP. If you own that public IP ...
Sorry, I couldn't find a proper figure to indicate my scenario exactly.
As you are aware, I have only one public IP.
Tomoyuki
