08-19-2010 02:56 AM - edited 03-19-2019 01:26 AM
When we register new phones using auto registration phone's line CSS is assign as none and can dail l External calls. We have CSS for STD ,Local and IDD. How to prevent to dial external when if phone lines is in none CSS (CUCM ver 7) Thanks
Bwawen
08-19-2010 03:00 AM
If your phones CSS is
You should ensure that all Route Patterns are placed into partitions, that are accessible only to the CSSs that you want to be able to dial externally.
Generally you should avoid all use of the
Aaron
08-19-2010 03:14 AM
Hi Aaron,
Thank you for the quick replay. How to ensure that all Route Patterns are placed into partitions, that are accessible only to the CSSs that you want to be able to dial externally.
How to avoid all use of the
Bawen
08-19-2010 06:30 AM
When you configure a route pattern you get to choose in which partition it will be.
Or if it's configured modify it's config to make sure it's in a partition.
I'd strongly recommend you to read this document to understand CSS and partitions.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/dialplan.html#wp1044276
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
