CSS Scripted keepalive
Aug 19th, 2010
Hi Guys,
I have a requirment to write a script to check the following;
Check a number of tcp ports, a perform a HTTP GET then look for a string match in the returned page.
Now, I am not really a coder but I can script the tcp port check and also the url get however I am not sure how to look for a string match.
Has anyone got an example or indeed done this before.
Thanks for you advice.
Scott
Gilles Dufour Thu, 08/19/2010 - 05:05
  • Cisco Employee,
You can look into existing http scriot with the command "show scrip ap-kal-httptag"
You will see that the command you need is 'socket waitfor ....' which will wait to see the string you want or timeout and declare the server down.
Gilles.
scott-goodwin Fri, 08/20/2010 - 03:05
Thankyou,
I managed to get it working, I will post on here later as it maybe usefull for others.
Scott
scott-goodwin Fri, 08/20/2010 - 04:12
!--- No echo.
!--- Parameters: Website IP, Web Page, Webstring, TCP Port(s)
!--- Description:
!--- This script will open and close a socket on the user specified ports.
!--- The close will be a FIN rather than a RST. If one of the ports fails,
!--- the service will be declared down
!--- If the ports are seen as up the script will then connect to the webserver
!--- Issue a GET and search the response for the defined string, if the search
!--- fails the service is deemed as down
!--- Failure Upon:
!--- 1. Not establishing a connection with the host on one of the specified port        s.
!--- 2. Unable to find the string in the GET request response.
!--- Will handle out of sockets scenario.
!--- will handle unable to connect.
!--- Written By Scott Goodwin
!-- Set the tcp connection error numbers
set OUT-OF-SOCKETS "785"
set NO-CONNECT "774"
!--- Make sure the user has a qualified number of arguments.
if ${ARGS}[#] "LT" "4"
  echo "Usage: ap-kal-custom-sg \'WebSiteIP WebPage WebString tcpPort1 [tcpPort2 tcpPort3...]\'"
  exit script 1
endbranch
!--- Set variables corresponding to the args.
set SERVICE "${ARGS}[1]"
set WebSite "${ARGS}[1]"
set WebPage "${ARGS}[2]"
set WebString "${ARGS}[3]"
set WebPort "80"
!--- Cycle through the variables to the tcpPorts
var-shift ARGS
var-shift ARGS
var-shift ARGS
while ${ARGS}[#] "GT" "0"
  set TCP-PORT "${ARGS}[1]"
  var-shift ARGS
echo "${TCP-PORT}"
  function SOCKET_CONNECT call
!--- If out of sockets, exit, and look for sockets on the next KAL interval.
  if RETURN "==" "${OUT-OF-SOCKETS}"
    set EXIT_MSG "Exceeded number of available sockets, skipping until next interval."
    exit script 0
  endbranch
!--- Valid connection, look to see if it was good.
  if RETURN "==" "${NO-CONNECT}"
    set EXIT_MSG "Connect: Failed to connect to ${SERVICE}:${TCP-PORT}"
    exit script 1
  endbranch
endbranch
no set EXIT_MSG
function SOCKET_CONNECT begin
  set CONTINUE_ON_ERROR "1"
  socket connect host ${SERVICE} port ${TCP-PORT} tcp 2000
  set SOCKET-STAT "${STATUS}"
  set CONTINUE_ON_ERROR "0"
  socket disconnect ${SOCKET} graceful
  function SOCKET_CONNECT return "${SOCKET-STAT}"
function SOCKET_CONNECT end
no set CONTINUE_ON_ERROR
no set EXIT_MSG
!-- Now check the url, perform a GET request and search for the defined string
echo "Requesting ${WebPage} from ${WebSite} on port ${WebPort}."
!--- Connect to the remote server.
set EXIT_MSG "Connect:  Failed.  Could not connect to ${WebSite} on port ${WebPort}"
socket connect host ${WebSite} port ${WebPort} tcp
if ${STATUS} "NEQ" "0"
  exit script 1
endbranch
!--- Request the desired Web page.
set EXIT_MSG "Send:  Failed.  Could not send to ${WebSite}:${WebPort}"
socket send ${SOCKET} "GET ${WebPage} HTTP/1.0\n\nHost: ${WebSite}:${WebPort}\n"
!--- Look for the Web string.
set EXIT_MSG "Waitfor:  Failed.  Did not find [${WebString}]"
socket waitfor ${SOCKET} "${WebString}" case-sensitive
  exit script 1
endbranch
!--- Disconnect from the server.
no set EXIT_MSG
