CatOS: How do I tag the native VLAN on a 802.1q trunk
Answered Question
Aug 19th, 2010
Hi Guys,
In IOS you can ask aswitch to tag yor native vlan traffic over a .1q trunk using the switchport trunk native vlan tag command. Is there an equivilant command in CatOS? And if so, can someone tell me what it is?
Thanks in advance
Cheers
Scott
Correct Answer by Lei Tian about 6 years 11 months ago
Hi Scott,
'set port dot1q-all-tagged' is the equivilant CATOS command. Check the command reference of your running release to see if this command is available.
HTH,
Lei Tian
Overall Rating: 5 (1 ratings)
Scott Cannon Thu, 08/19/2010 - 03:47
Doesnt this set the native vlan? I already have my native vlan set (the default 1) I just want to have packets for that vlan tagged on the trunk link, and I'd prefer to do it without changing native vlan.
Will this command do the job? (I dont have a test environment so I'm relying on NetPro's experiences before implementing)
Cheers
Scott
KARUPPUCHAMY MA... Thu, 08/19/2010 - 03:59
  • Silver, 250 points or more
The command which imentioned in my thread will set the native vlan from vlan 1 to the new native vlan(by default native vlan is 1).
Generally all the frames will have their own vlan tag id.
Frames belonging to the Native VLAN do NOT carry VLAN tags when sent over the trunk. Conversely, if an untagged frame is received on a trunk port, the frame is associated with the Native VLAN for this port.
Hope it will clarify your doubt.
Samy
Scott Cannon Thu, 08/19/2010 - 04:02
Regarding your comment "Frames belonging to the Native VLAN do NOT carry VLAN tags when sent over the trunk." this is normally true. However ou can ove-ride this in IOS using the command "sw trunk nat vlan tag"
I seek the same command for CatOS. I cant find it anywhere.... perhaps CatOS doesnt support this feature...
Rgds
Scott
Correct Answer
Lei Tian Thu, 08/19/2010 - 04:03
  • Cisco Employee,
Hi Scott,
HTH,
Lei Tian
Scott Cannon Thu, 08/19/2010 - 04:19
Thanks Lei.
You wouldnt beleive how hard it is to find something so simple on the internet. Much appreciated. Did the trick nicely.
Cheers
Scott
Lei Tian Thu, 08/19/2010 - 06:11
  • Cisco Employee,
Yes, totally agree. When I search myself on internet, google always give me other people with same name.
Glad to help!
Cheers
Lei Tian
