Tunnel working in one direction - All IPSec SA proposals found unacceptable!
Aug 19th, 2010
Hello
If I match traffic on the ASA towards the 877 the tunnel comes up 100%
If I match traffic on the 877 towards the ASA the tunnel is not coming up - I get below from a debug
…(lines removed)…
Aug 19 12:48:12 [IKEv1]: Group = 1.1.1.136, IP = 1.1.1.136, PHASE 1 COMPLETED
...(lines removed)…
Aug 19 12:48:12 [IKEv1]: Group = 1.1.1.136, IP = 1.1.1.136, Static Crypto Map check, map outside_map, seq = 5 is a successful match
Aug 19 12:48:12 [IKEv1]: Group = 1.1.1.136, IP = 1.1.1.136, IKE Remote Peer configured for crypto map: outside_map
Aug 19 12:48:12 [IKEv1 DEBUG]: Group = 1.1.1.136, IP = 1.1.1.136, processing IPSec SA payload
Aug 19 12:48:12 [IKEv1]: Group = 1.1.1.136, IP = 1.1.1.136, All IPSec SA proposals found unacceptable!
Aug 19 12:48:12 [IKEv1 DEBUG]: Group = 1.1.1.136, IP = 1.1.1.136, sending notify message
Aug 19 12:48:12 [IKEv1 DEBUG]: Group = 1.1.1.136, IP = 1.1.1.136, constructing blank hash payload
Aug 19 12:48:12 [IKEv1 DEBUG]: Group = 1.1.1.136, IP = 1.1.1.136, constructing ipsec notify payload for msg id 3e05497d
Aug 19 12:48:12 [IKEv1 DEBUG]: Group = 1.1.1.136, IP = 1.1.1.136, constructing qm hash payload
Aug 19 12:48:12 [IKEv1]: IP = 1.1.1.136, IKE_DECODE SENDING Message (msgid=fc4879ef) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Aug 19 12:48:12 [IKEv1]: Group = 1.1.1.136, IP = 1.1.1.136, QM FSM error (P2 struct &0xd8c6e6b0, mess id 0x3e05497d)!
Aug 19 12:48:12 [IKEv1 DEBUG]: Group = 1.1.1.136, IP = 1.1.1.136, IKE QM Responder FSM error history (struct &0xd8c6e6b0)  <state>, <event>:  QM_DONE, EV_ERROR-->QM_BLD_MSG2, EV_NEGO_SA-->QM_BLD_MSG2, EV_IS_REKEY-->QM_BLD_MSG2, EV_CONFIRM_SA-->QM_BLD_MSG2, EV_PROC_MSG-->QM_BLD_MSG2, EV_HASH_OK-->QM_BLD_MSG2, NullEvent-->QM_BLD_MSG2, EV_COMP_HASH
Aug 19 12:48:12 [IKEv1 DEBUG]: Group = 1.1.1.136, IP = 1.1.1.136, sending delete/delete with reason message
Aug 19 12:48:12 [IKEv1]: Group = 1.1.1.136, IP = 1.1.1.136, Removing peer from correlator table failed, no match!
See relevant configuration below
877
crypto isakmp policy 5
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key abc123 address 2.2.2.220
crypto ipsec transform-set TRANS esp-3des esp-md5-hmac
crypto map TUNNEL_2_64 10 ipsec-isakmp
set peer 2.2.2.220
set transform-set TRANS
match address TUNNEL
interface Dialer1
ip nat inside source list NAT interface Dialer1 overload
ip access-list extended NAT
deny   ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
deny   ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
permit ip 192.168.1.0 0.0.0.255 any
ip access-list extended TUNNEL
permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
permit ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
permit ip host 1.1.1.136 host 2.2.2.220
permit ip host 2.2.2.220 host 1.1.1.136
ASA
name 192.168.2.0 sitex
name 192.168.1.0 sitey
interface Vlan2
nameif outside
security-level 0
ip address 2.2.2.28.220 255.255.255.248
access-list outside_1_cryptomap extended permit ip 192.168.2.0 255.255.255.0 sitex 255.255.255.0
access-list outside_1_cryptomap extended permit ip sitex 255.255.255.0 192.168.2.0 255.255.255.0
access-list outside_1_cryptomap extended permit icmp host 2.2.2.220 host 1.1.1.136
access-list outside_1_cryptomap extended permit icmp host 1.1.1.136 host 2.2.2.220
access-list outside_1_cryptomap extended permit ip host 2.2.2.220 host 1.1.1.136
access-list outside_1_cryptomap extended permit ip host 1.1.1.136 host 2.2.2.220
crypto ipsec transform-set TEST_TRANS esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer 1.1.1.136
crypto map outside_map 1 set transform-set TEST_TRANS
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
encryption 3des
hash md5
group 2
lifetime 86400
tunnel-group 1.1.1.136 type ipsec-l2l
tunnel-group 1.1.1.136 ipsec-attributes
pre-shared-key *
Jennifer Halim Thu, 08/19/2010 - 05:29
The crypto ACL is incorrect.
Assuming that ASA LAN is 192.168.2.0/24 and router LAN is 192.168.1.0/24, the following ACL should be configured:
On the router:
On the ASA:
access-list outside_1_cryptomap extended permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
The rest of the other ACL lines that have been configured should be removed. Most importantly, the number of ACL line on the router should match the same on the ASA with mirror image ACL for the subnet.
You also need to remove the following on the ASA as the router is not configured to use PFS:
Hope that helps.
