Question about upgrading JTAPI
Answered Question
Aug 19th, 2010
We will be upgrading CallManager from 4.1 to 6.x and will need to upgrade jtapi that runs on multiple PG's.  When you upgrade jtapi do you install on top of the current jtapi or do you uninstall then reinstall?  I have searched for documentation but have come up with nothing.
Correct Answer by Justin Brenton about 6 years 8 months ago
Hi there,
Please see the following doc
http://developer.cisco.com/c/document_library/get_file?folderId=192392&name=DLFE-11403.pdf
HTH, Please rate if so.
Justin
Overall Rating: 5 (2 ratings)
Mr_toad1_2 Thu, 08/19/2010 - 10:55
The pdf had what I was looking for.  Thanks!
Warning
Installation of the new software may fail if you do not first manually uninstall any Release 4.X or earlier version of the JTAPI SDK.
