08-19-2010 05:41 AM - edited 03-04-2019 09:29 AM
hi,
looking for a router from Cisco router family, which is outdoor rated and supports G.SHDSL.
also, does Cisco MAR 3200 Series supports G.SHDSL
regards
srihari
08-19-2010 06:04 AM
A simple search would have revelaed:
http://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78_459542.html
Note: no router is "outdoor rated" meaning it can rain on it. Some router have rugged features like the 3200 you mentioned. If you have one already, you should know its characteristics.
Also there are interface cards to be used with modular routers. You can search cisco.com for specifications then cotnact your Cisco reseller for prices and availability.
08-19-2010 06:13 AM
understood but customer is looking for outdoor rated, to the best of my knowledge Cisco doesnt have any outdoor rated routers.
also the local service provider has suggested to go for 3200 series but i cant see any feature support for G.SHDSL
08-19-2010 06:16 AM
Your customer is seriosuly mistaken, all routers from all makers are indoor devices.
If you read the data sheet and the documentation, you will learn all the features opf 3200 and any other Cisco prodcut.
08-19-2010 06:26 AM
ok, let me update and take a note on this.
thanks for your support
08-19-2010 06:33 AM
You are welcome, please remember to rate useful posts clicking on the stars below.
