Scripting Question
Answered Question
Is it possible to have agents assigned to the same CSQ's but have two separate scripts and two separate CTI_RP?
Correct Answer by Aaron Harrison about 6 years 9 months ago
Yes, completely normal and possible.
You can send calls to a single CSQ from as many scripts as you like. You basically refer to the same 'CSQ' in two scripts on your Select step.
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Thu, 08/19/2010 - 05:58
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
