Cisco Host Scan interoperability with WSUS
Aug 19th, 2010
we want to implement through the Cisco Secure Desktop Manager, an endpoint check about the os patching.
We notice that is possible to check from the DAP to check the os update.
Is it possible to query the microsoft WSUS service in order to check the endpoint os version to correct patch?
Paul Carco Sat, 09/04/2010 - 10:15
Yes you can do this using an 'Logical Expression'  within your DAP configuration
Checking for a Hotfix on the User PC
This example checks for a specific hotfix. If a user does not have the hotfix on their PC, a message that it is not installed displays.
(not CheckAndMsg(EVAL(endpoint.os.windows.hotfix["KB923414"],"EQ","true"),nil,"The
required hotfix is not installed on your PC."))
or you could define it this way (which makes more sense):
(CheckAndMsg(EVAL(endpoint.os.windows.hotfix["KB923414"],"NE","true"),"The required hotfix
is not installed on your PC.",nil))
You can build the expression in this example because the debug dap trace returns:
endpoint.os.windows.hotfix["KB923414"] = "true";
-- This is from the ASDM online Help..
Best regards,
Paul
