Todd Pula Thu, 08/19/2010 - 07:51
  • Silver, 250 points or more
Please refer to the discussion below for more information.  You can try to add the following registry values to a machine with the patch installed.
https://supportforums.cisco.com/docs/DOC-12602
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\SecurityProviders\SCHAN​N​EL
add the following 2 DWORD values:
AllowInsecureRenegoServers   value:  1
UseScsvForTls   value:  1
dougweaver Fri, 08/20/2010 - 04:33
Please see the attached document.  It has worked well for us in situations where regulation or software such as McAfee HBSS interfere with your ability to uninstall the patch.  Since you obviously have no access to our U: drive, you can obtain the proper version of Schannel.dll from a functioning Windows machine.
