nslookup timeout problem with SA 520 fw 1.1.42
Aug 19th, 2010
we have some timeout problems with dns lookups made through our SA 520.
I have searched this discussion fora and found a few related cases:
This case for instance is describing almost the same behaviour with a SA 520w. Then the solution seamed to be to upgrade to fw 1.1.21. Though that release note doesn't mention this to be resolved?
https://supportforums.cisco.com/thread/2018831
However we have had this problem in both 1.1.42 and 1.1.21.
(I see that 1.1.65 is out, but a search in the release notes after "dns" has no relevant hits, so there are noe reason to believa an upgrade will help.)
What happens after some SA520 uptime is that the dns requests starts to time out. (We uses an outside DNS server)
This happens with all clients with multiple OS. (A restart of SA 520 postpones the issue for some time.)
However after manually doing a lookup in the SA 520 webinterface results in (updating the cache?) resolving (slow though) the address.
So clearly there are even in 1.1.42 some issus with this?
Below are some printouts
- Here is one lookup done with a windows client
C:\Users>nslookup www.cisco.com
Server:  dnscache1.dataguard.no
Address:  213.158.233.130
DNS request timed out.
    timeout was 2 seconds.
*** Forespørsel for å dnscache1.dataguard.no tidsavbrutt
C:\Users>
- At the same time, another request from a linux client:
[email protected]:~$ nslookup www.cisco.com
;; connection timed out; no servers could be reached
- Then I go to Administration | Diagnostics in the SA 520, and executes the same DNS lookup there:
Address:    72.163.4.161
- This then results in that all clients are able to resolve the address for some time, though still slow:
Windows client:
Server:  UnKnown
Ikke-autoritativt svar:
Navn:    origin-www.cisco.com
Aliases:  www.cisco.com
          www.cisco.com.akadns.net
          geoprod.cisco.com.akadns.net
C:\Users>
Linux client:
Server:         213.158.233.131
Address:        213.158.233.131#53
Non-authoritative answer:
www.cisco.com   canonical name = www.cisco.com.akadns.net.
www.cisco.com.akadns.net        canonical name = geoprod.cisco.com.akadns.net.
geoprod.cisco.com.akadns.net    canonical name = origin-www.cisco.com.
jwraalsen Fri, 09/10/2010 - 16:52
Hi, and thanks for your answer.
We just experienced some of these timeouts again, and I then generated and downloaded the dbglog as instructed.
In firefox this just hanged forever, but in IE it resulted in a tgz archive. This archive however does not contain an obvious log file to PM to you.
And I couldn't find any way to attach files to the PM system?
Please give me instructions on which logfile you need, and I'll be happy to send it to you.
regards
John
vianet.ca Tue, 11/22/2011 - 05:28
I am experiencing this exact same problem and have been for the last 2 firmware releases.  I've upgraded my 520W to
2.1.71 last week and the problem has actually worsened since the upgrade.  Was there ever a fix worked out for this issue?
vianet.ca Wed, 11/23/2011 - 09:56
I've tried several versions of firmware for the SA520W and factoried my router once just be sure there wasn't some erroneous enabled by accident which could be causing some grief, nothing worked.  However, I think I may have found the problem.  Under Firewall > Attacks > LAN Security Checks; there is an option titled "Block UDP flood" which is enabled by default.  I've disabled this option and things seem to be fine now.
streaves Mon, 11/28/2011 - 11:46
  • Cisco Employee,
Thanks for the update and special thanks for sharing with the Community.
Stephanie Reaves
Cisco Small Business
Related Content
