Cisco asa ipsec vpn with Iphone idle timeout problem
Aug 19th, 2010
I just configured my asa5510 8.2.3 to get an iphone connected in a ipsec vpn.
The tunnel vpn is correctly established but when the iphone goes in safe mode (after 1 minute) the tunnel goes down.
Is there any particular settings to keep the tunnel up?
Yudong Wu Thu, 08/19/2010 - 09:59
Not sure if you changed the default timer on phase 1 and 2.
If not, you can configure the following two parameter in the related group policy for iPhone
please refer to the cmd reference for the detail.
acleri Fri, 08/27/2010 - 07:16
no solution found, iphone terminate the connection when change in safe mode.
