How to retag a 4300G DMP?
Aug 19th, 2010
I have a 4300G DMP but I need to use DMS 5.2, this DMP doesn't support this version but I heard that if you retag it as 4305G is possible to make the upgrade to 5.2. Anyone knows how to do this? I really appreciate your help! Thank you and have a nice day!
Tomas De Leon Fri, 08/20/2010 - 13:29
Retagging a DMP-4300G to become or look like a DMP-4305G is not a supported
task or procedure.  Altering your DMP-4300G will invalidate any service aggreements
that you may have on the DMP.
DMP-4300G is NOT supported with DMS version 5.2.x.   If you need or want to go to
DMS 5.2.x for your DMS install, I would recommend that you purchase DMP-4400G or the
upcoming DMP-4310G to replace your DMP-4300\05G devices.
Please contact a Cisco Partner, Your Cisco Account Rep or Sale Rep for more details.
