LMS Commands Deployment
Answered Question
Aug 19th, 2010
i have Cisco LMS 3.0 and i want to deploy a command to all of my network Devices e.g Username , how can i do this
Correct Answer by Joe Clarke about 6 years 9 months ago
You can use Netconfig to do this.  Go to RME > Config Mgmt > Netconfig > Netconfig Jobs and create a new job.  You can pick your devices, and the configuration template you wish to deploy.  If a template does not exist, then you an use the Adhoc template to deploy any commands you want down to the devices.  Consult the Netconfig online help for more details.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Mon, 08/30/2010 - 11:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
